PJM6403PSG
PJM6403PSG
    PJ(平晶)
    SOT23-6
    MOSFETS SOT23-6 P-Channel VDS=30V VGS=±20V Id=6A RDS(on)=24mΩ
PJM6403PSG 数据手册
PJM6403PSG P-Channel Enhancement Mode Power MOSFET SOT-23-6 Features ⚫ Low gate charge 4.S ⚫ High density cell design for ultra low RDS(on) 5.D ⚫ VDS= -30V,ID= -6A RDS(on)< 35mΩ @VGS= -10V 3.G 6.D 2.D 1.D Marking Code:6403 Pin Assignment Applications ⚫ PWM applications ⚫ Load switch ⚫ Power management Schematic Diagram D D D D G S 1、2、5、6:Drain 3:Gate Top View 4:Source Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Drain-Source Voltage -VDS 30 V Gate-Source Voltage VGS ±20 V Drain Current-Continuous -ID -6 A Drain Current-Pulsed Note1 -IDM 30 A Maximum Power Dissipation PD 1.4 W Junction Temperature TJ 150 °C TSTG -55 to +150 °C RθJA 89 °C/W Storage Temperature Range Thermal Characteristics Thermal Resistance,Junction-to-Ambient www.pingjingsemi.com Revision:1.0 Apr-2022 1/7 PJM6403PSG P-Channel Enhancement Mode Power MOSFET Electrical Characteristics (Ta=25℃ unless otherwise specified) Parameter Symbol Test Condition Min. Typ. Max. Unit Drain-Source Breakdown Voltage -V(BR)DSS VGS=0V,ID=-250μA 30 -- -- V Zero Gate Voltage Drain Current -IDSS VDS=-30V,VGS=0V -- -- 1 μA Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V -- -- ±100 nA Gate Threshold Voltage Note2 -VGS(th) VDS=VGS,ID=-250μA 1.0 1.35 2.5 V Drain-Source On-Resistance Note2 RDS(on) VGS=-10V,ID=-6A -- 24 35 mΩ VGS=-4.5V,ID=-5A -- 33 58 mΩ VDS=-5V,ID=-6A -- 11 -- S -- 760 -- pF -- 140 -- pF Static Characteristics Forward Transconductance Note2 gFS Dynamic Characteristics Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss -- 95 -- pF Turn-on Delay Time td(on) -- 13 -- nS Turn-on Rise Time tr VDD=-15V, ID=-1A -- 15 -- nS Turn-off Delay Time td(off) VGS=-10V,RGEN=6Ω -- 198 -- nS VDS=-15V,VGS=0V,f=1MHz Switching Characteristics Turn-off Fall Time tf -- 98 -- nS Total Gate Charge Qg -- 52 -- nC Gate-Source Charge Qgs -- 9.8 -- nC Gate-Drain Charge Qgd -- 8.3 -- nC -- -- 1.2 V -- -- 6 A VDS=-15V,ID=-6A, VGS=-10V Source-Drain Diode Characteristics Diode Forward Voltage Note2 Diode Forward Current -VSD VGS=0V,IS=-6A -IS Note: 1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature. 2. Pulse Test: Pulse width≤300μs, duty cycle≤2%. www.pingjingsemi.com Revision:1.0 Apr-2022 2/7 PJM6403PSG P-Channel Enhancement Mode Power MOSFET Typical Characteristic Curves -ID Drain Current (A) -ID Drain Current (A) TC=-55℃ 125℃ VGS=1V -VGS Gate-Source Voltage (V) -IS Source Current (A) RDS(on) On-Resistance (mΩ) -VDS Drain-Source Voltage (V) -ID Drain Current (A) TC=150℃ TC=25℃ TC=-50℃ -VSD Source-Drain Voltage (V) VDS=-15V ID=-8A C Capacitance (pF) -VGS Gate-Source Voltage (V) 25℃ QG Gate Charge (nC) www.pingjingsemi.com Revision:1.0 Apr-2022 -VDS Drain-Source Voltage (V) 3/7 PJM6403PSG P-Channel Enhancement Mode Power MOSFET -ID Drain Current (A) Normalized Breakdown Voltage -V(BR)DSS Limited by RDS(ON) TA=25℃ Single Pulse TJ Junction Temperature (℃) www.pingjingsemi.com Revision:1.0 Apr-2022 -VDS Drain-Source Voltage (V) 4/7 PJM6403PSG P-Channel Enhancement Mode Power MOSFET Package Outline SOT-23-6 Dimensions in mm 2.92 ±0.1 0.127 +0.05/-0.02 10 1.6 2.8 ±0.1 ±0.1 1.9±0.1 12 R0.15MAX 0.95±0.1 0.35±0.05 R0.15MAX 0.06 12 ± 0.05 0.65 ±0.1 1.1 ±0.1 10 Ordering Information Device Package Shipping PJM6403PSG SOT-23-6 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:1.0 Apr-2022 5/7 PJM6403PSG P-Channel Enhancement Mode Power MOSFET Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:1.0 Apr-2022 6/7 PJM6403PSG P-Channel Enhancement Mode Power MOSFET Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23-6 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 B C E Symbol A B C E F D T1 T2 Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F 1.55±0.05 3.50±0.05 2.00±0.05 1.10±0.10 4.00±0.10 8±0.10 4.00±0.10 1.75±0.10 Reel (7'') Pin1 Tape (8mm) www.pingjingsemi.com Revision:1.0 Apr-2022 7/7
PJM6403PSG 价格&库存
很抱歉,暂时无法提供与“PJM6403PSG”相匹配的价格&库存,您可以联系我们找货
