PJ9570M12DFC
PJ9570M12DFC
    PJ(平晶)
    DFN-6(2x2)
    3.3V 500MA 6.5V
PJ9570M12DFC 数据手册
PJ9570 Series Low Dropout Regulators Description SOT-23 3.VIN The PJ9570 Series are highly precise,low noise,positive voltage LDO regulators manufactured using CMOS processes. The PJ9570 performance is optimized for battery-powered systems to deliver ultra low noise and low quiescent current. Regulator ground current increases only slightly in dropout, further prolonging the 1.GND 2.VOUT battery life. The PJ9570 Series also works with low-ESR ceramic capacitors, SOT-23-3 reducing the amount of board space necessary for power applications, critical in 3.VIN hand-held wireless devices. The PJ9570 Series consumes less than 1μA in shutdown mode and has fast turn-on time less than 50s. The other features include ultra low dropout voltage, high output accuracy, current limiting protection, and high ripple rejection ratio. Features 1.GND ⚫ Ultra Low Noise for RF Application 2.VOUT SOT-89 ⚫ Ultra Fast Response in Line/Load Transient 2.VIN ⚫ Low Power Consumption:70uA(Typ.) ⚫ PSRR=75dB@1KHz ⚫ Maximum Output Current: 500mA ⚫ Low Dropout : 100mV @ 100mA at VOUT=3.3V ⚫ Operating Voltage Ranges : 2V to 6.5V 1.GND 2.VIN 3.VOUT ⚫ Over Temperature and Current Limiting Protection ⚫ Thermal Shutdown Protection SOT-23-5 4. NC 5. VOUT Applications ⚫ Battery-Powered Equipment ⚫ CDMA/GSM Cellular Handsets ⚫ Audio/Video Equipment 1.VIN Marking Code 9570 -XX XX:Output Voltage e.g. 3.0:3.0V 3.3:3.3V www.pingjingsemi.com Revision:2.0 Aug-2021 2.GND 3.EN DFN2x2C-6L 6.VIN 1.VOUT 5.NC 2.NC 4.EN 3.GND 1 / 11 PJ9570 Series Low Dropout Regulators Functional Pin Description Pin Name Pin Function EN Chip Enable (Active High). Note that this pin is high impedance NC NO Connected GND Ground VOUT Output Voltage VIN Power Input Voltage Ordering Information PJ9570- Package Type SA:SOT-23 SC:SOT-23-3 SQ:SOT-89 SE:SOT-23-5 DFC : DFN2x2C-6L Output Voltage 12 : 1.2V 15 : 1.5V 18 : 1.8V 25 : 2.5V 28 : 2.8V 30 : 3.0V 33 : 3.3V 36 : 3.6V Output current tap M : 500mA Typical Application Circuit PJ9570 VIN CIN 1µF Chip Enable www.pingjingsemi.com Revision:2.0 Aug-2021 VIN VOUT GND EN COUT 1µF VOUT NC 2 / 11 PJ9570 Series Low Dropout Regulators Function Block Diagram www.pingjingsemi.com Revision:2.0 Aug-2021 3 / 11 PJ9570 Series Low Dropout Regulators Absolute Maximum Ratings Note1 Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Value Unit -0.3 ~ +7 V -0.3 ~ +0.3 V -0.3~VIN+0.3 V SOT-23 200 mW SOT-89 400 mW SOT-23-3 250 mW SOT-23-5 250 mW DFN2x2C-6L 560 mW SOT-23 500 °C/W SOT-89 250 °C/W SOT-23-3 400 °C/W SOT-23-5 400 °C/W DFN2x2C-6L 180 °C/W -40 ~ +85 °C 260 °C -40 ~ +125 °C ESD(HBM) Note2 4 KV ESD(CDM) Note2 400 V VIN,VEN to GND Voltage VIN VON/OFF VOUT to VIN Voltage Power Dissipation Thermal Resistance,Junction-to-Ambient Operating Ambient Temperature Junction temperature Storage temperature range Note 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions may affect device reliability. 2. ESD testing is performed according to the respective JESD22 JEDEC standard. The human body model is a 100pF capacitor discharged through a 1.5KΩ resistor into each pin.The machine model is a 200pF capacitor discharged into each pin. Parameter Supply Voltage Value Unit 2 ~ 6.5 V Operating Junction Temperature Range TJ -40 ~ +125 °C Operating Free Air Temperature Range TA -40 ~ +85 °C www.pingjingsemi.com Revision:2.0 Aug-2021 4 / 11 PJ9570 Series Low Dropout Regulators Electrical Characteristics (VIN=VOUT+1, VOUT = 3.3V, CIN=1µF, COUT=1µF, TA=25℃ , unless otherwise noted.) Parameter Input Voltage Symbol Test Conditions VIN Output Voltage Accuracy Quiescent Current Min. Typ. Max. Unit -0.3 -- 6.5 V ∆VOUT IOUT=40mA -2 -- +2 % IQ VIN>VOUT,EN=VIN IOUT=0mA -- 70 -- μA IOUT=100mA -- 100 -- IOUT=200mA -- 220 -- mV Dropout Voltage Note1 VDROP Line Regulation ∆VLINE VIN=VOUT+1 to 7V,IOUT=40mA -- 0.05 -- %/V Load Regulation ∆VLOAD 1mA
PJ9570M12DFC 价格&库存
很抱歉,暂时无法提供与“PJ9570M12DFC”相匹配的价格&库存,您可以联系我们找货
