PJ75BL33SE
PJ75BL33SE
    PJ(平晶)
    SOT23-5
    3.3V 200MA 36V
PJ75BL33SE 数据手册
PJ75B Series Low Dropout Regulators Description SOT-23 3.VIN The PJ75B series is a set of three-terminal low power high voltage regulators implemented in CMOS technology. They allow input voltages as high as 36V. They are available with several fixed output voltages ranging from 1.8V to 5.0V. The device features integrated short-circuit and thermal shutdown protection. 1.GND 2.VOUT SOT-23-3 Features 3.VIN ⚫ Wide input voltage range from 3V to 36V ⚫ Up to 200mA Load Current ⚫ Low voltage drop ⚫ Quiescent current : 2.5μA ⚫ Output voltage tolerance : ±2% 1.GND ⚫ Available Packages : SOT-23, SOT-23-3, SOT-89, SOT-23-5 2.VOUT SOT-89 2.VIN Applications ⚫ Battery-Powered Equipment ⚫ Ultra Low Power Microcontrollers ⚫ Security Monitoring Equipment 1.GND 2.VIN 3.VOUT SOT-23-5 4. NC 5. NC 1.GND www.pingjingsemi.com Revision:2.0 Jul-2022 2.VIN 3.VOUT 1 / 11 PJ75B Series Low Dropout Regulators Functional Pin Description Pin Name Pin Function NC NO Connected GND Ground VOUT Output Voltage VIN Power Input Voltage Marking Code Note Output Voltage Package Marking Code 1.8V~5V SOT-23 75XX 1.8V~5V SOT-23-3 75XXC 1.8V~5V SOT-23-5 75XXE 1.8V~5V SOT-89 75XX Note . XX : Output Voltage e.g . 50:5.0V Ordering Information PJ75- Package Type SA : SOT-23 SC : SOT-23-3 SQ : SOT-89 SE : SOT-23-5 Output Voltage 18 : 1.8V 25 : 2.5V 30 : 3.0V 33 : 3.3V 36 : 3.6V 50 : 5.0V Output current tap L: 150mA Revision:B www.pingjingsemi.com Revision:2.0 Jul-2022 2 / 11 PJ75B Series Low Dropout Regulators Function Block Diagram Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Value Unit -0.3 ~ +40 V SOT-23 300 mW SOT-23-3 400 mW SOT-23-5 400 mW SOT-89 600 mW SOT-23 380 °C/W SOT-23-3 300 °C/W SOT-23-5 300 °C/W SOT-89 180 °C/W Operating Junction Temperature -40 ~ +125 °C Storage Temperature Range -65 ~ +150 °C 300 °C +2000 V Supply Voltage Power Dissipation Thermal Resistance,Junction-to-Ambient Lead Temperature (Soldering, 10 sec) ESD(HBM mode, ESDA/JEDECJS-001-2017) www.pingjingsemi.com Revision:2.0 Jul-2022 3 / 11 PJ75B Series Low Dropout Regulators Electrical Characteristics (VIN=VOUT+2, CIN=1µF, COUT=1µF, TA=25℃ , unless otherwise noted.) Parameter Symbol Input Voltage Test Conditions Min. Typ. Max. Unit 3 -- 36 V -2 -- +2 % 150 -- -- mA -- 2.5 4 μA IOUT=150mA -- 1250 1450 mV IOUT=100mA -- 880 1050 mV IOUT=150mA -- 1150 1350 mV IOUT=100mA -- 800 1000 mV IOUT=150mA -- 820 960 mV IOUT=100mA -- 530 700 mV IOUT=150mA -- 800 950 mV IOUT=100mA -- 520 680 mV IOUT=150mA -- 750 930 mV IOUT=100mA -- 500 660 mV IOUT=150mA -- 670 900 mV IOUT=100mA -- 420 600 mV -- -- 0.2 %/V -- 25 60 mV -- 80 -- mA -- 120 -- μVRMS -- 68 -- dB VIN Output Voltage Accuracy ∆VOUT Maximum Output Current IOUT(Max) Quiescent Current IOUT=1mA IQ IOUT=0mA VOUT=1.8V VOUT=2.5V VOUT=3.0V Dropout Voltage VDROP VOUT=3.3V VOUT=3.6V VOUT=5.0V Line Regulation ∆VLINE Load Regulation ∆VLOAD Short Current Protection VIN=VOUT+2V to 30V IOUT=10mA VIN=VOUT+2V, 1mA
PJ75BL33SE 价格&库存
很抱歉,暂时无法提供与“PJ75BL33SE”相匹配的价格&库存,您可以联系我们找货
PJ75BL33SE
  • 10+0.44540
  • 100+0.35208
  • 300+0.30543
库存:391
