MPSA92SQ
PNP Transistor
Features
SOT-89
Ideal for switching and amplifier applications
Ideally suited for automated assembly processes
Equivalent Circuit
2.Collector
1.Base 2.Collector 3. Emitter
Marking Code : MPSA92
1.Base
3.. Emitter
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
-VCBO
300
V
Collector Emitter Voltage
-VCEO
300
V
Emitter Base Voltage
-VEBO
5
V
Collector Current
-IC
500
mA
Maximum Power Dissipation
PD
500
mW
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revison:3.0 Feb-2022
1/7
MPSA92SQ
PNP Transistor
Electrical Characteristics (TA=25℃)
Parameter
Symbol
Min.
Max.
Unit
25
40
25
-ICBO
0.25
μA
-IEBO
0.1
μA
-V(BR)CBO
300
V
-V(BR)CEO
300
V
-V(BR)EBO
5
V
-VCE(sat)
0.5
V
-VBE(sat)
0.9
V
FT
50
MHz
Cob
6
pF
DC Current Gain
at VCE = -10 V, IC = -1 mA
at VCE = -10 V, IC = -10 mA
HFE
at VCE = -10 V, IC = -30 mA
Collector Base Cutoff Current
at VCB = -200V
Emitter Base Cutoff Current
at VEB = -3 V
Collector Base Breakdown Voltage
at IC = -100 μA
Collector Emitter Breakdown Voltage
at IC = -1 mA
Emitter Base Breakdown Voltage
at IE = -100 μA
Collector Emitter Saturation Voltage
at IC = -20 mA, IB = -2 mA
Base Emitter Saturation Voltage
Transition Frequency
at VCE = -20 V, IC = -10 mA, f = 100 MHz
Output Capacitance
at VCB = -20 V, f = 1 MHz
2/7
MPSA92SQ
PNP Transistor
Typical Characteristic Curves
1000
-20
-100uA
-15
-80uA
-70uA
-10
-60uA
-50uA
-40uA
-5
Ta=100℃
hFE
-90uA
DC Current Gain
Collector Current IC (mA)
Common
Emitter
Ta=25℃
100
Ta=25℃
-30uA
-20uA
-0
VCE= -10V
IB=-10uA
-0
-2
-4
-6
-8
-10
-12
10
-10
-14
Collector-Emitter Voltage VCE (mV)
-100
-200
-400
-1000
Collector-Emitter Saturation Voltage
VCEsat (mV)
Base-Emitter Saturation Voltage
VBEsat (mV)
β=10
-800
Ta=25℃
-600
Ta=100℃
-400
-300
-200
Ta=100℃
-100
Ta=25℃
β=10
-200
-1
-10
-0
-100
-1
-10
-100
-200
1000
f=1MHz
IE=0 / IC=0
Ta=25℃
-100
Capacitance C (pF)
-150
Ta=100℃
Ta=25℃
100
Cib
10
Cob
-50
VCE= -10V
-0
-200
-400
-600
Base-Emitter Voltage VBE (mV)
-800
-1000
1
-0.1
-1
-10
-20
Reverse Voltage VR (V)
3/7
MPSA92SQ
PNP Transistor
Package Outline
SOT-89
Dimensions in mm
Ordering Information
Device
Package
MPSA92SQ
SOT-89
Shipping
1,000PCS/Reel&7inches
3,000PCS/Reel&13inches
4/7
MPSA92SQ
PNP Transistor
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/7
MPSA92SQ
PNP Transistor
Package Specifications
The method of packaging (1,000PCS/Reel&7inches)
Cover Tape
1,000 pcs per reel
SOT-89
Carrier Tape
8,000 pcs per box
8 reels per box
32,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T1
E
B
G
F
Reel (7'')
symbol
Value(unit:mm)
A
Φ179±1
B
60.5±0.2
C
15.3±0.3
D
12.5~13.7
E
Φ13.5±0.2
F
Φ10.0±0.2
G
2.7±0.2
T1
1.0±0.2
C
6/7
MPSA92SQ
PNP Transistor
The method of packaging (3,000PCS/Reel&13inches)
3,000 pcs per reel
SOT-89
9,000 pcs per box
3 reels per box
36,000 pcs per carton
4 boxes per carton
B
A
T
E
D
F
Reel (13'')
symbol
Value(unit:mm)
A
Φ330±1
B
12.7±0.5
C
16.5±0.3
D
Φ99.5±0.5
E
Φ13.6±0.3
F
2.8±0.3
T1
1.9±0.2
C
7/7
很抱歉,暂时无法提供与“MPSA92SQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38362
- 100+0.30327
- 300+0.26309
