MMDT3906SG
Double PNP Transistors
Features
SOT-23-6
For switching and amplifier applications
4.C2
5.E1
3.B2
6.C1
Equivalent Circuit
2.E2
1.B1
Marking Code
3906
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
-VCBO
40
V
Collector Emitter Voltage
-VCEO
40
V
Emitter Base Voltage
-VEBO
6
V
Collector Current
-IC
200
mA
Maximum Power Dissipation
PD
1
W
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revision:1.0 Mar-2021
1/6
MMDT3906SG
Electrical Characteristics (TA=25℃)
Parameter
Symbol
Min.
Max.
Unit
60
80
100
300
at VCE = -1 V, IC = -50 mA
60
at VCE = -1 V, IC = -100 mA
30
-ICBO
.50
nA
-IEBO
50
nA
-V(BR)CBO
40
V
-V(BR)CEO
40
V
-V(BR)EBO
6
V
-VCE(sat)
0.25
V
0.4
0.65
0.85
0.95
FT
250
MHz
Cob
4.5
pF
DC Current Gain
at VCE = -1 V, IC = -0.1 mA
at VCE = -1 V, IC = -1 mA
at VCE = -1 V, IC = -10 mA
Collector Base Cutoff Current
at VCB = -30V
Emitter Base Cutoff Current
at VEB = -6 V
Collector Base Breakdown Voltage
at IC = -10 μA
Collector Emitter Breakdown Voltage
at IC = -1 mA
Emitter Base Breakdown Voltage
at IE = -10 μA
HFE
Collector Emitter Saturation Voltage
at IC = -10 mA, IB = -1 mA
at IC = -50 mA, IB = -5 mA
Base Emitter Saturation Voltage
-VBE(sat)
Transition Frequency
at VCE = -20 V, IC = -10 mA,f = 100 MHz
Output Capacitance
at VCB = -5 V, IE = 0, f = 1 MHz
V
2/6
MMDT3906SG
Typical Characteristic Curves
Collector-Emitter Saturation Voltage
VCE(sat) (V)
IC/IB=10
DC Current Gain hFE
Ta=125℃
Ta=-25℃
Ta=+25℃
VCE=1.0V
Collector Current IC (mA)
Base-Emitter Saturation Voltage
VBE(sat) (V)
Output Capacitance Cob (pF)
f=1MHz
IC/IB=10
Cob
Collector-Base Voltage VCB (V)
3/6
MMDT3906SG
Package Outline
SOT-23-6
Dimensions in mm
2.92
±0.1
0.127 +0.05/-0.02
10
1.6
2.8
±0.1
±0.1
1.9±0.1
12
R0.15MAX
0.95±0.1
0.35±0.05
R0.15MAX
0.06
12
± 0.05
0.65
±0.1
1.1
±0.1
10
Ordering Information
Device
Package
Shipping
MMDT3906SG
SOT-23-6
3,000PCS/Reel&7inches
4/6
MMDT3906SG
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/6
MMDT3906SG
Package Specifications
The method of packaging
Cover Tape
3,000 pcs per reel
SOT-23-6
Carrier Tape
30,000 pcs per box
10 reels per box
120,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T2
T1
Symbol
A
B
C
E
F
D
T1
T2
B
C
E
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
F
1.55±0.05
3.50±0.05
2.00±0.05
1.10±0.10
4.00±0.10
8±0.10
4.00±0.10
1.75±0.10
Reel (7'')
Pin1
Tape (8mm)
6/6
很抱歉,暂时无法提供与“MMDT3906SG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.10258
- 200+0.07880
- 600+0.06558
- 3000+0.05768
- 9000+0.05081
- 21000+0.04711
