MMDT2222ASG
Double NPN Transistors
Features
SOT-23-6
For switching and amplifier applications
4.C2
5.E1
3.B2
6.C1
Equivalent Circuit
2.E2
1.B1
Marking Code
2222A
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
75
V
Collector Emitter Voltage
VCEO
40
V
Emitter Base Voltage
VEBO
6
V
Collector Current
IC
600
mA
Maximum Power Dissipation
PD
1
W
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revision:1.0 Mar-2021
1/6
MMDT2222ASG
Electrical Characteristics (TA=25℃)
Parameter
Symbol
Min.
Max.
Unit
at VCE = 10 V, IC = 0.1 mA
35
at VCE = 10 V, IC = 1 mA
50
75
at VCE = 1 V, IC = 150 mA
50
at VCE = 10 V, IC = 150 mA
100
300.
at VCE = 10 V, IC = 500 mA
40
ICBO
10
nA
IEBO
100
nA
V(BR)CBO
75
V
V(BR)CEO
40
V
V(BR)EBO
6
V
VCE(sat)
0.3
V
1.0
0.6
1.2
2.0
FT
300
MHz
Cob
8
pF
DC Current Gain
at VCE = 10 V, IC = 10 mA
Collector Base Cutoff Current
at VCB = 60 V
Emitter Base Cutoff Current
at VEB = 3 V
Collector Base Breakdown Voltage
at IC = 10 μA
Collector Emitter Breakdown Voltage
at IC = 10 mA
Emitter Base Breakdown Voltage
at IE = 10 μA
HFE
Collector Emitter Saturation Voltage
at IC = 150 mA, IB = 15 mA
at IC = 500 mA, IB = 50 mA
Base Emitter Saturation Voltage
VBE(sat)
Transition Frequency
at VCE = 20 V, IE = -20 mA, f = 100 MHz
Output Capacitance
at VCB = 10 V, f = 100 KHz
V
2/6
MMDT2222ASG
Typical Characteristic Curves
Ta=25℃
DC Current Gain hFE
Collector Current IC (mA)
Ta=25℃
VCE=10V
1V
Collector-Emitter Voltage VCE (V)
VCE=10V
DC Current Gain hFE
Collector-Emitter Saturation Voltage
VCE(sat) (V)
Ta=25℃
IC/IB=10
Ta=125℃
25℃
-55℃
Base-Emitter Saturation Voltage
VBE(sat) (V)
Ta=25℃
IC/IB=10
3/6
MMDT2222ASG
Package Outline
SOT-23-6
Dimensions in mm
2.92
±0.1
0.127 +0.05/-0.02
10
1.6
2.8
±0.1
±0.1
1.9±0.1
12
R0.15MAX
0.95±0.1
0.35±0.05
R0.15MAX
0.06
12
± 0.05
0.65
±0.1
1.1
±0.1
10
Ordering Information
Device
Package
Shipping
MMDT2222ASG
SOT-23-6
3,000PCS/Reel&7inches
4/6
MMDT2222ASG
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/6
MMDT2222ASG
Package Specifications
The method of packaging
Cover Tape
3,000 pcs per reel
SOT-23-6
Carrier Tape
30,000 pcs per box
10 reels per box
120,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T2
T1
Symbol
A
B
C
E
F
D
T1
T2
B
C
E
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
F
1.55±0.05
3.50±0.05
2.00±0.05
1.10±0.10
4.00±0.10
8±0.10
4.00±0.10
1.75±0.10
Reel (7'')
Pin1
Tape (8mm)
6/6
很抱歉,暂时无法提供与“MMDT2222ASG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.30640
- 200+0.25272
- 600+0.22292
