MMBTSC3356S
MMBTSC3356S
    PJ(平晶)
    SOT-23
    通用三极管 SOT23 NPN VCEO=12V VCE(sat)=0.5V Ic=0.1A PD=200mW
MMBTSC3356S 数据手册
MMBTSC3356 NPN Transistor Features  SOT-23 For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code: MMBTSC3356Q : J4Q MMBTSC3356R : J4R MMBTSC3356S : J4S 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage VCBO 20 V Collector Emitter Voltage VCEO 12 V Emitter Base Voltage VEBO 3 V Collector Current IC 100 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 ℃ TSTG -65 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Mar-2021 1/6 MMBTSC3356 NPN Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 50 -- 100 80 -- 160 125 -- 250 ICBO -- -- 1 μA IEBO -- -- 1 μA V(BR)CBO 20 -- -- V V(BR)CEO 12 -- -- V V(BR)EBO 3 -- -- V VCE(sat) -- -- 0.5 V FT -- 7 -- GHZ CreNote1 -- -- 1 pF DC Current Gain at VCE = 10 V, IC = 20 mA Gain Group Q R HFE S Collector Base Cutoff Current at VCB = 10V Emitter Base Cutoff Current at VEB = 1 V Collector Base Breakdown Voltage at IC = 10 μA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 10 μA Collector Emitter Saturation Voltage at IC = 10 mA, IB = 5 mA Transition Frequency at VCE = 10 V, IC = 20 mA Feed-Back Capacitance at VCB = 10 V, f = 1 MHz -- Note1:The emitter terminal and the case shall be connected to the guard terminal of the three-terminal capacitance bridge. www.pingjingsemi.com Revision:2.0 Mar-2021 2/6 MMBTSC3356 NPN Transistor Typical Characteristic Curves www.pingjingsemi.com Revision:2.0 Mar-2021 3/6 MMBTSC3356 NPN Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBTSC3356 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Mar-2021 4/6 MMBTSC3356 NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Mar-2021 5/6 MMBTSC3356 NPN Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Mar-2021 6/6
MMBTSC3356S 价格&库存
很抱歉,暂时无法提供与“MMBTSC3356S”相匹配的价格&库存,您可以联系我们找货
