MMBTA10
MMBTA10
    PJ(平晶)
    SOT-23
    通用三极管 SOT23 NPN VCEO=25V VCE(sat)=0.5V Ic=0.1A PD=200mW
MMBTA10 数据手册
MMBTA10 NPN Transistor Features  SOT-23 For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code : A10 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage VCBO 30 V Collector Emitter Voltage VCEO 25 V Emitter Base Voltage VEBO 3 V Collector Current IC 100 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Mar-2021 1/5 MMBTA10 NPN Transistor Electrical Characteristics (TA=25℃) Parameter DC Current Gain at VCE = 10 V, IC = 4 mA Collector Base Cutoff Current at VCB = 25 V Emitter Base Cutoff Current at VEB = 2 V Collector Base Breakdown Voltage at IC = 100 μA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 10 μA Collector Emitter Saturation Voltage at IC = 4 mA, IB = 0.4 mA Base Emitter On Voltage at VCE = 10 V, IC = 4 mA Transition Frequency at VCE = 10 V, IC = 4 mA, f = 100 MHz Output Capacitance at VCB = 10 V, f = 1 MHz Collector Base Feedback Capacitance at VCB = 10 V, f = 1 MHz www.pingjingsemi.com Revision:2.0 Mar-2021 Symbol Min. Max. Unit HFE 60 -- -- ICBO -- 100 nA IEBO -- 100 nA V(BR)CBO 30 -- V V(BR)CEO 25 -- V V(BR)EBO 3 -- V VCE(sat) -- 0.5 V VBE(on) -- 0.95 V FT 650 -- MHz Cob -- 0.7 pF Crb 0.35 0.65 pF 2/5 MMBTA10 NPN Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBTA10 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Mar-2021 3/5 MMBTA10 NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Mar-2021 4/5 MMBTA10 NPN Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Mar-2021 5/5
MMBTA10 价格&库存
很抱歉,暂时无法提供与“MMBTA10”相匹配的价格&库存,您可以联系我们找货
