MMBT9014C
MMBT9014C
    PJ(平晶)
    SOT-23
    通用三极管 SOT23 NPN VCEO=45V VCE(sat)=0.25V Ic=0.1A PD=200mW
MMBT9014C 数据手册
MMBT9014 NPN Transistor SOT-23 Features  For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code : MMBT9014B : 1W MMBT9014C : 1F MMBT9014D : 1H 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage VCBO 50 V Collector Emitter Voltage VCEO 45 V Emitter Base Voltage VEBO 5 V Collector Current IC 100 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Mar-2021 1/6 MMBT9014 NPN Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 110 -- 220 200 -- 450 420 -- 800 ICBO -- -- 50 nA IEBO -- -- 50 nA V(BR)CBO 50 -- -- V V(BR)CEO 45 -- -- V V(BR)EBO 5 -- -- V VCE(sat) -- -- 0.25 V VBE(sat) -- -- 1 V FT 100 -- -- MHz Cob -- -- 6 pF DC Current Gain at VCE = 5 V, IC = 1 mA Gain Group B C HFE D Collector Base Cutoff Current at VCB = 50 V Emitter Base Cutoff Current at VEB = 5 V Collector Base Breakdown Voltage at IC = 100 μA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 100 μA Collector Emitter Saturation Voltage at IC = 100 mA, IB = 10 mA Base Emitter Saturation Voltage at IC = 100 mA, IB = 5 mA Transition Frequency at VCE = 5 V, IC = 10 mA Output Capacitance at VCB = -10 V, f = 1 MHz www.pingjingsemi.com Revision:2.0 Mar-2021 -- 2/6 MMBT9014 NPN Transistor DC Current Collector Current hFE IC (mA) Typical Characteristic Curves VCE (V) Revision:2.0 Mar-2021 IC (mA) Transition Frequency Saturation Voltage Collector Current www.pingjingsemi.com Collector Current fT (MHz) VBE(sat),VCE(sat) (mV) Collector-Emitter Voltage IC (mA) Collector Current IC (mA) 3/6 MMBT9014 NPN Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBT9014 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Mar-2021 4/6 MMBT9014 NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Mar-2021 5/6 MMBT9014 NPN Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Mar-2021 6/6
MMBT9014C 价格&库存
很抱歉,暂时无法提供与“MMBT9014C”相匹配的价格&库存,您可以联系我们找货
