MMBT9012H
MMBT9012H
    PJ(平晶)
    SOT-23
    PNP 电流:500MA 电压:30V
MMBT9012H 数据手册
MMBT9012 PNP Transistor SOT-23 Features  For Switching and AF Amplifier Applications. Equivalent Circuit 1.Base 2.Emitter 3.Collector 3.Collector Marking Code : MMBT9012G : K2 MMBT9012H : K3 1.Base 2.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage -VCBO 40 V Collector Emitter Voltage -VCEO 30 V Emitter Base Voltage -VEBO 5 V Collector Current -IC 500 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revision:2.0 Mar-2021 1/6 MMBT9012 PNP Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 100 -- 250 160 -- 400 40 -- -- -ICBO -- -- 100 nA -IEBO -- -- 100 nA -V(BR)CBO 40 -- -- V -V(BR)CEO 30 -- -- V -V(BR)EBO 5 -- -- V -VCE(sat) -- -- 0.6 V -VBE(sat) -- -- 1.2 V -VBE -- -- 1 V FT -- 100 -- MHz DC Current Gain at VCE = -1 V, IC = -50 mA Gain Group G H HFE at VCE = -1 V, IC = -500 mA Collector Base Cutoff Current at VCB = -35 V Emitter Base Cutoff Current at VEB = -5 V Collector Base Breakdown Voltage at IC = -100 μA Collector Emitter Breakdown Voltage at IC = -1 mA Emitter Base Breakdown Voltage at IE = -100 μA Collector Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Base Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Base Emitter Voltage at VCE = -1 V, IC = -100 mA Transition Frequency at VCE = -5 V, IC = -10 mA www.pingjingsemi.com Revision:2.0 Mar-2021 -- 2/6 MMBT9012 PNP Transistor 300 Collector Current IC (mA) Power Dissipation PD (mW) Typical Characteristic Curves 250 200 150 100 50 0 0 25 50 75 100 125 150 Base-Emitter Voltage VBE (V ) Collector Current IC (mA) Collector-Emitter Saturation Voltage VCE(sat) (V ) Ambient Temperature Ta (℃ ) Collector-Emitter Voltage VCE (V ) DC Current Gain hFE DC Current Gain hFE Collector Current IC (mA) www.pingjingsemi.com Revision:2.0 Mar-2021 Collector Current IC (mA) Collector Current IC (mA) 3/6 MMBT9012 PNP Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBT9012 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Mar-2021 4/6 MMBT9012 PNP Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Mar-2021 5/6 MMBT9012 PNP Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Mar-2021 6/6
MMBT9012H 价格&库存
很抱歉,暂时无法提供与“MMBT9012H”相匹配的价格&库存,您可以联系我们找货
