BCX52SQ-16
BCX52SQ-16
    PJ(平晶)
    SOT89-3
    通用三极管 SOT89 PNP VCEO=60V VCE(sat)=0.5V Ic=1A PD=500mW
BCX52SQ-16 数据手册
BCX52SQ PNP Transistor Features SOT-89 ⚫ Low voltage ⚫ High collector current ⚫ As Complementary Type of the NPN Transistor BCX55SQ is Recommended Equivalent Circuit 1.Base 2.Collector 3. Emitter 2.Collector Marking Code : 1.Base BCX52 -XX 3.. Emitter XX: 10/16 Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage -VCBO 60 V Collector Emitter Voltage -VCEO 60 V Emitter Base Voltage -VEBO 5 V Collector Current -IC 1 A Peak Collector Current -ICM 1.5 A Maximum Power Dissipation PD 500 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range Thermal Characteristics Parameter Thermal Resistance Junction to Ambient www.pingjingsemi.com Revison:3.0 Feb-2022 Symbol Value Unit RθJA 250 ℃/W 1/7 BCX52SQ PNP Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 63 -- -- 63 -- 160 100 -- 250 40 -- -- -ICBO -- -- 100 nA -IEBO -- -- 100 nA -V(BR)CBO 60 -- -- V -V(BR)CEO 60 -- -- V -V(BR)EBO 5 -- -- V -VCE(sat) -- -- 0.5 V -VBE(on) -- -- 1 V FT -- 50 -- MHz DC Current Gain at VCE = -2 V, IC = -5 mA at VCE = -2 V, IC = -150 mA BCX52SQ-10 HFE BCX52SQ-16 at VCE = -2 V, IC = -500 mA Collector Base Cutoff Current at VCB = -30 V Emitter Base Cutoff Current at VEB = -5 V Collector Base Breakdown Voltage at IC = -100 μA Collector Emitter Breakdown Voltage at IC = -1 mA Emitter Base Breakdown Voltage at IE = -100 μA Collector Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Base Emitter On Voltage at VCE = -2 V, IC = -500 mA Transition Frequency at VCE = -5 V, IC = -10 mA, f = -100 MHz www.pingjingsemi.com Revison:3.0 Feb-2022 -- 2/7 BCX52SQ PNP Transistor Typical Characteristic Curves -400 1000 VCE= -2V Common Emitter Ta=25℃ -350 hFE -1.8mA -1.6mA -250 -1.4mA DC Current Gain IC (mA) Collector Current Ta=100℃ -2.0mA -300 -1.2mA -200 -1.0mA -150 -0.8mA -0.6mA -100 100 Ta=25℃ -0.4mA -50 -0 IB=-0.2mA -0 -1 -2 -3 -4 -5 10 -6 -1 -10 Collcetor-Emitter Voltage VCE (V) -1000 IC (mA) -400 -1000 β=10 β=10 Collector-Emitter Saturation Voltage VCEsat (mV) -800 Base-Emitter Saturation Voltage VBEsat (mV) -100 Collector Current Ta=25℃ -600 -400 Ta=100℃ -200 -200 Ta=100℃ -100 Ta=25℃ -0 -0.1 -1 -10 Collector Current -100 -0 -0.1 -1000 -1 IC (mA) -10 Collector Current 150 -100 -1000 IC (mA) 1000 f=1MHz IE=0 / IC=0 Capacitance C (pF) Trancition Frequency fT (MHz) Ta=25℃ 100 50 100 Cib Cob 10 VCE=-5V Ta=25℃ 0 -0 -20 -40 Collector Current -60 -80 1 -0.1 -100 -10 -20 Reverse Voltage VR (V) 0.75 -1000 Power Dissipaiotn PD (W) IC (mA) -100 Collector Current -1 IC (mA) Ta=100℃ -10 Ta=25℃ -1 0.50 0.25 VCE=-2V -0.1 -0 -200 -400 -600 Base-Emitter Voltage VBE (mV) www.pingjingsemi.com Revison:3.0 Feb-2022 -800 -1000 0.00 0 25 50 75 100 125 150 Ambient Temperature Ta (℃) 3/7 BCX52SQ PNP Transistor Package Outline SOT-89 Dimensions in mm Ordering Information Device Package BCX52SQ SOT-89 www.pingjingsemi.com Revison:3.0 Feb-2022 Shipping 1,000PCS/Reel&7inches 3,000PCS/Reel&13inches 4/7 BCX52SQ PNP Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revison:3.0 Feb-2022 5/7 BCX52SQ PNP Transistor Package Specifications  The method of packaging (1,000PCS/Reel&7inches) Cover Tape 1,000 pcs per reel SOT-89 Carrier Tape 8,000 pcs per box 8 reels per box 32,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T1 E B G F Reel (7'') www.pingjingsemi.com Revison:3.0 Feb-2022 symbol Value(unit:mm) A Φ179±1 B 60.5±0.2 C 15.3±0.3 D 12.5~13.7 E Φ13.5±0.2 F Φ10.0±0.2 G 2.7±0.2 T1 1.0±0.2 C 6/7 BCX52SQ PNP Transistor Package Specifications  The method of packaging (3,000PCS/Reel&13inches) 3,000 pcs per reel SOT-89 9,000 pcs per box 3 reels per box 36,000 pcs per carton 4 boxes per carton  Embossed tape and reel data B A T E D F Reel (13'') www.pingjingsemi.com Revison:3.0 Feb-2022 symbol Value(unit:mm) A Φ330±1 B 12.7±0.5 C 16.5±0.3 D Φ99.5±0.5 E Φ13.6±0.3 F 2.8±0.3 T1 1.9±0.2 C 7/7
BCX52SQ-16 价格&库存
很抱歉,暂时无法提供与“BCX52SQ-16”相匹配的价格&库存,您可以联系我们找货
