2SB766ASQ-R
2SB766ASQ-R
    PJ(平晶)
    SOT89-3
    PNP,三极管 VCEO:-50V,IC:-1A,PD:0.5W, HFE:120~240,VCE(SAT):-0.4V(MAX)
2SB766ASQ-R 数据手册
2SB766ASQ PNP Transistor Features SOT-89 ⚫ Low saturation votage ⚫ Large power dissipation Equivalent Circuit 2.Collector 1.Base 2.Collector 3. Emitter Marking Code : 2SB766ASQ-Q : BQ 2SB766ASQ-R : BR 2SB766ASQ-S : BS 1.Base 3.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage -VCBO 60 V Collector Emitter Voltage -VCEO 50 V Emitter Base Voltage -VEBO 5 V Collector Current -IC 1 A Maximum Power Dissipation PD 0.5 W Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revison:2.0 Feb-2022 1/7 2SB766ASQ PNP Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 85 -- 170 120 -- 240 170 -- 340 50 -- -- -ICBO -- -- 0.1 μA -IEBO -- -- 0.1 μA -V(BR)CBO 60 -- -- V -V(BR)CEO 50 -- -- V -V(BR)EBO 5 -- -- V -VCE(sat) -- -- 0.4 V -VBE(sat) -- -- 1.2 V FT -- 200 -- MHz Cob -- -- 30 pF DC Current Gain at VCE = -10 V, IC = -500 mA Current Gain Group Q R S HFE at VCE = -5 V, IC = -1 A Collector Base Cutoff Current at VCB = -20V Emitter Base Cutoff Current at VEB = -4 V Collector Base Breakdown Voltage at IC = -10 μA Collector Emitter Breakdown Voltage at IC = -2 mA Emitter Base Breakdown Voltage at IE = -10 μA Collector Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Base Emitter Saturation Voltage at IC = -500 mA, IB = -50 mA Transition Frequency at VCE = -10 V, IC = -50 mA, f = 200 MHz Output Capacitance at VCB = -10 V, IE=0, f = 1 MHz www.pingjingsemi.com Revison:2.0 Feb-2022 -- 2/7 2SB766ASQ PNP Transistor Typical Characteristic Curves 1000 -1200 -5mA -4.5mA -4mA -3.5mA o Ta=100 C -3mA -800 DC Current Gain hFE Collector Current IC (mA) -1000 Common Emitter Ta=25℃ -2.5mA -600 -2mA -1.5mA -400 o Ta=25 C 100 -1mA -200 VCE= -10V IB=-0.5mA -0 -0 -2 -4 -6 -8 Collector-Emitter Voltage -10 -12 10 -10 -14 -100 VCE (V) -1000 Collector Current -1000 IC (mA) -400 -800 Collector-Emitter Saturation Voltage VCE(sat) (mV) Base-Emitter Saturation Voltage VBE(sat) (mV) β=10 Ta=25℃ -600 Ta=100℃ -400 -300 -200 Ta=100℃ -100 Ta=25℃ β=10 -200 -1 -10 -100 Collector Current -0 -1000 -1 -10 -100 Collector Current IC (mA) -1000 IC (mA) -1000 f=1MHz IE=0 / IC=0 o Ta=25 C (pF) Cib 100 C -600 o Ta=100 C Capacitance Collector Current IC (mA) -800 Ta=25℃ -400 Cob 10 -200 VCE=-10V -0 -200 -400 -600 Base-Emitter Voltage -800 VBE -1 -10 Reverse Voltage (mV) 300 0.6 250 0.5 VR -20 (V) (W) (MHz) PD 200 Power Dissipation fT Transition Frequency 1 -0.1 -1000 150 100 50 VCE=-10V 0.4 0.3 0.2 0.1 o Ta=25 C 0 -0 -20 -40 Collector Current www.pingjingsemi.com Revison:2.0 Feb-2022 -60 IC (mA) -80 -100 0.0 0 25 50 75 100 125 150 Ambient Temperature Ta (℃) 3/7 2SB766ASQ PNP Transistor Package Outline SOT-89 Dimensions in mm Ordering Information Device Package 2SB766ASQ SOT-89 www.pingjingsemi.com Revison:2.0 Feb-2022 Shipping 1,000PCS/Reel&7inches 3,000PCS/Reel&13inches 4/7 2SB766ASQ PNP Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revison:2.0 Feb-2022 5/7 2SB766ASQ PNP Transistor Package Specifications  The method of packaging (1,000PCS/Reel&7inches) Cover Tape 1,000 pcs per reel SOT-89 Carrier Tape 8,000 pcs per box 8 reels per box 32,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T1 E B G F Reel (7'') www.pingjingsemi.com Revison:2.0 Feb-2022 symbol Value(unit:mm) A Φ179±1 B 60.5±0.2 C 15.3±0.3 D 12.5~13.7 E Φ13.5±0.2 F Φ10.0±0.2 G 2.7±0.2 T1 1.0±0.2 C 6/7 2SB766ASQ PNP Transistor Package Specifications  The method of packaging (3,000PCS/Reel&13inches) 3,000 pcs per reel SOT-89 9,000 pcs per box 3 reels per box 36,000 pcs per carton 4 boxes per carton  Embossed tape and reel data B A T E D F Reel (13'') www.pingjingsemi.com Revison:2.0 Feb-2022 symbol Value(unit:mm) A Φ330±1 B 12.7±0.5 C 16.5±0.3 D Φ99.5±0.5 E Φ13.6±0.3 F 2.8±0.3 T1 1.9±0.2 C 7/7
2SB766ASQ-R 价格&库存
很抱歉,暂时无法提供与“2SB766ASQ-R”相匹配的价格&库存,您可以联系我们找货
