2SAR553SQ
PNP Transistor
Features
SOT-89
Low saturation voltage
As Complementary Type of the NPN
Transistor 2SCR553SQ is Recommended
Equivalent Circuit
2.Collector
1.Base 2.Collector 3. Emitter
Marking Code : DL
1.Base
3.. Emitter
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
-VCBO
50
V
Collector Emitter Voltage
-VCEO
50
V
Emitter Base Voltage
-VEBO
6
V
Collector Current
-IC
2
A
Maximum Power Dissipation
PD
0.5
W
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revison:4.0 May-2022
1/7
2SAR553SQ
PNP Transistor
Electrical Characteristics (TA=25℃)
Parameter
DC Current Gain
at VCE = -2 V, IC = -50 mA
Collector Base Cutoff Current
at VCB = -50 V
Emitter Base Cutoff Current
at VEB = -4 V
Collector Base Breakdown Voltage
at IC = -100 μA
Collector Emitter Breakdown Voltage
at IC = -1 mA
Emitter Base Breakdown Voltage
at IE = -100 μA
Collector Emitter Saturation Voltage
at IC = -700 mA, IB = -35 mA
Base Emitter Saturation Voltage
at IC = -500 mA, IB = -50 mA
Transition Frequency
at VCE = -10 V, IE = -300 mA, f=100MHz
Symbol
Min.
Typ.
Max.
Unit
HFE
180
450
-ICBO
0.1
μA
-IEBO
0.1
μA
-V(BR)CBO
50
V
-V(BR)CEO
50
V
-V(BR)EBO
6
V
-VCE(sat)
0.4
V
-VBE(sat)
1.2
V
FT
320
MHz
2/7
2SAR553SQ
PNP Transistor
Typical Characteristics Curves
0.12
-VCE(sat) Collector Emitter
Saturation Voltage (V)
hFE DC Current Gain
350
300
250
200
150
100
50
0.1
0.08
0.06
0.04
0.02
10
100
-IC Colector Current (mA)
1000
1
10
100
1000
3/7
2SAR553SQ
PNP Transistor
Package Outline
SOT-89
Dimensions in mm
Ordering Information
Device
Package
2SAR553SQ
SOT-89
Shipping
1,000PCS/Reel&7inches
3,000PCS/Reel&13inches
4/7
2SAR553SQ
PNP Transistor
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/7
2SAR553SQ
PNP Transistor
Package Specifications
The method of packaging (1,000PCS/Reel&7inches)
Cover Tape
1,000 pcs per reel
SOT-89
Carrier Tape
8,000 pcs per box
8 reels per box
32,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T1
E
B
G
F
Reel (7'')
symbol
Value(unit:mm)
A
Φ179±1
B
60.5±0.2
C
15.3±0.3
D
12.5~13.7
E
Φ13.5±0.2
F
Φ10.0±0.2
G
2.7±0.2
T1
1.0±0.2
C
6/7
2SAR553SQ
PNP Transistor
The method of packaging (3,000PCS/Reel&13inches)
3,000 pcs per reel
SOT-89
9,000 pcs per box
3 reels per box
36,000 pcs per carton
4 boxes per carton
B
A
T
E
D
F
Reel (13'')
symbol
Value(unit:mm)
A
Φ330±1
B
12.7±0.5
C
16.5±0.3
D
Φ99.5±0.5
E
Φ13.6±0.3
F
2.8±0.3
T1
1.9±0.2
C
7/7
很抱歉,暂时无法提供与“2SAR553SQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40835
- 100+0.32282
- 300+0.28005
