2N5551SQ
2N5551SQ
    PJ(平晶)
    SOT89-3
    NPN,VCEO:160V,IC:0.6A,PD:0.5W,VCE(SAT):0.2V(MAX.),HFE:30-250
2N5551SQ 数据手册
2N5551SQ NPN Transistor Features ⚫ SOT-89 For Switching and AF Amplifier Applications Equivalent Circuit 2.Collector 1.Base 2.Collector 3. Emitter Marking Code : BG1 1.Base 3.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage VCBO 180 V Collector Emitter Voltage VCEO 160 V Emitter Base Voltage VEBO 6 V Collector Current IC 600 mA Maximum Power Dissipation PD 500 mW Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Storage Temperature Range www.pingjingsemi.com Revison:3.0 Feb-2022 1/7 2N5551SQ NPN Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Max. Unit 80 -- 80 250 30 -- ICBO -- 50 nA IEBO -- 50 nA V(BR)CBO 180 -- V V(BR)CEO 160 -- V V(BR)EBO 6 -- V VCE(sat) -- 0.15 V -- 0.2 -- 1 -- 1 FT 100 300 MHz Cob -- 6 pF DC Current Gain at VCE = 5 V, IC = 1 mA at VCE = 5 V, IC = 10 mA HFE at VCE = 5 V, IC = 50 mA Collector Base Cutoff Current at VCB = 120 V Emitter Base Cutoff Current at VEB = 4 V Collector Base Breakdown Voltage at IC = 100 μA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 10 μA -- Collector Emitter Saturation Voltage at IC = 10 mA, IB = 1 mA at IC = 50 mA, IB = 5 mA Base Emitter Saturation Voltage at IC = 10 mA, IB = 1 mA VBE(sat) at IC = 50 mA, IB = 5 mA Transition Frequency at VCE = 10 V, IC = 10 mA, f = 100 MHz Output Capacitance at VCB =10 V, f = 1 MHz www.pingjingsemi.com Revison:3.0 Feb-2022 V 2/7 2N5551SQ NPN Transistor Typical Characteristic Curves www.pingjingsemi.com Revison:3.0 Feb-2022 3/7 2N5551SQ NPN Transistor Package Outline SOT-89 Dimensions in mm Ordering Information Device Package 2N5551SQ SOT-89 www.pingjingsemi.com Revison:3.0 Feb-2022 Shipping 1,000PCS/Reel&7inches 3,000PCS/Reel&13inches 4/7 2N5551SQ NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revison:3.0 Feb-2022 5/7 2N5551SQ NPN Transistor Package Specifications  The method of packaging (1,000PCS/Reel&7inches) Cover Tape 1,000 pcs per reel SOT-89 Carrier Tape 8,000 pcs per box 8 reels per box 32,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T1 E B G F Reel (7'') www.pingjingsemi.com Revison:3.0 Feb-2022 symbol Value(unit:mm) A Φ179±1 B 60.5±0.2 C 15.3±0.3 D 12.5~13.7 E Φ13.5±0.2 F Φ10.0±0.2 G 2.7±0.2 T1 1.0±0.2 C 6/7 2N5551SQ NPN Transistor Package Specifications  The method of packaging (3,000PCS/Reel&13inches) 3,000 pcs per reel SOT-89 9,000 pcs per box 3 reels per box 36,000 pcs per carton 4 boxes per carton  Embossed tape and reel data B A T E D F Reel (13'') www.pingjingsemi.com Revison:3.0 Feb-2022 symbol Value(unit:mm) A Φ330±1 B 12.7±0.5 C 16.5±0.3 D Φ99.5±0.5 E Φ13.6±0.3 F 2.8±0.3 T1 1.9±0.2 C 7/7
2N5551SQ 价格&库存
很抱歉,暂时无法提供与“2N5551SQ”相匹配的价格&库存,您可以联系我们找货
2N5551SQ
  • 1000+0.19440
  • 2000+0.19116
  • 4000+0.18630
  • 8000+0.17820
