13001SQ
NPN Transistor
Features
SOT-89
High Voltage and High speed switch
Equivalent Circuit
2.Collector
1.Base 2.Collector 3. Emitter
Marking Code : 13001
1.Base
3.. Emitter
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
700
V
Collector Emitter Voltage
VCEO
420
V
Emitter Base Voltage
VEBO
10
V
Collector Current
IC
150
mA
Maximum Power Dissipation
PD
550
mW
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revison:3.0 Feb-2022
1/7
13001SQ
NPN Transistor
Electrical Characteristics (TA=25℃)
Parameter
DC Current Gain
at VCE = 20 V, IC = 10 mA
Collector Base Cutoff Current
at VCB = 700V
Collector Emitter Cutoff Current
at VCE = 420V
Emitter Base Cutoff Current
at VEB = 10 V
Collector Base Breakdown Voltage
at IC = 100 μA
Collector Emitter Breakdown Voltage
at IC = 1 mA
Emitter Base Breakdown Voltage
at IE = 100 μA
Collector Emitter Saturation Voltage
at IC = 50 mA, IB = 10 mA
Base Emitter Saturation Voltage
Transition Frequency
at VCE = 10 V, IC = 50 mA, f = 1 MHz
Symbol
Min.
Max.
Unit
HFE
15
25
ICBO
100
μA
ICEO
100
μA
IEBO
100
μA
V(BR)CBO
700
V
V(BR)CEO
420
V
V(BR)EBO
10
V
VCE(sat)
1.05
V
VBE(sat)
1.55
V
FT
5
MHz
2/7
13001SQ
NPN Transistor
VBE(sat) (V)
VCE(sat) (V)
Typical Characteristic Curves
Collector Current IC (A)
Storage Time
tS (μs)
3/7
13001SQ
NPN Transistor
Package Outline
SOT-89
Dimensions in mm
Ordering Information
Device
Package
13001SQ
SOT-89
Shipping
1,000PCS/Reel&7inches
3,000PCS/Reel&13inches
4/7
13001SQ
NPN Transistor
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/7
13001SQ
NPN Transistor
Package Specifications
The method of packaging (1,000PCS/Reel&7inches)
Cover Tape
1,000 pcs per reel
SOT-89
Carrier Tape
8,000 pcs per box
8 reels per box
32,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T1
E
B
G
F
Reel (7'')
symbol
Value(unit:mm)
A
Φ179±1
B
60.5±0.2
C
15.3±0.3
D
12.5~13.7
E
Φ13.5±0.2
F
Φ10.0±0.2
G
2.7±0.2
T1
1.0±0.2
C
6/7
13001SQ
NPN Transistor
The method of packaging (3,000PCS/Reel&13inches)
3,000 pcs per reel
SOT-89
9,000 pcs per box
3 reels per box
36,000 pcs per carton
4 boxes per carton
B
A
T
E
D
F
Reel (13'')
symbol
Value(unit:mm)
A
Φ330±1
B
12.7±0.5
C
16.5±0.3
D
Φ99.5±0.5
E
Φ13.6±0.3
F
2.8±0.3
T1
1.9±0.2
C
7/7
很抱歉,暂时无法提供与“13001SQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.58461
- 100+0.48870
- 300+0.44075
- 1000+0.40479
