MMDTA143Z
MMDTA143Z
    PJ(平晶)
    SOT23-6
    两个PNP,R1:4.7K R2:47K, 功率(Pd):200mW 输出电流(-Io):100mA 集射极击穿电压(-Vceo):50V
MMDTA143Z 数据手册
MMDTA143Z Double Silicon PNP Digital Transistor SOT-23-6 Features  Simplify circuit design  With built-in bias resistors: R1=4.7KΩ, R2=47KΩ 4 5 3 6 2 Equivalent Circuit 1 C1 B2 C2 E1 B1 E2 1.Emitter1 2.Base1 3.Emitter2 4.Collector2 5.Base2 6.Collector1 Resistor Values/Marking Code Type R1 (KΩ) R2 (KΩ) Marking Code MMDTA143Z 4.7 47 143Z Absolute Maximum Ratings (TA=25℃) Parameter Symbol Value Unit Output Voltage -VO 50 V Input Voltage -VI 30,-5 V Output Current -IO 100 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 °C TSTG -55 to +150 °C Storage Temperature Range www.pingjingsemi.com Revision:2.0 Sep-2021 1/6 MMDTA143Z Double Silicon PNP Digital Transistor Electrical Characteristics (TA=25℃) Parameter DC Current Gain at VO = -5 V, IO = -10 mA Output Cutoff Current at VO = -50 V Input Current at VI = -5 V Output Voltage (ON) at IO = -10 mA, II = -0.5 mA Input Voltage (ON) at VO = -0.3 V, IO = -2 mA Input Voltage (OFF) at VO = -5 V, IO = -0.1 mA Transition Frequency at VO = -10 V, IO = -5 mA www.pingjingsemi.com Revision:2.0 Sep-2021 Symbol Min. Typ. Max. Unit GI 80 -- -- -- -IO(OFF) -- -- 500 nA -II -- -- 1.8 mA -VO(ON) -- -- 0.3 V -VI(ON) -- -- 1.3 V -VI(OFF) 0.5 -- -- V fT -- 250 -- MHz 2/6 MMDTA143Z Double Silicon PNP Digital Transistor Output Current IO (mA) Input Voltage VI(OFF) (V) Typical Characteristic Curves Input Voltage VI(OFF) (V) DC Current Gian GI Output Voltage VO (mV) Output Current IO (mA) Output Current IO (mA) www.pingjingsemi.com Revision:2.0 Sep-2021 Output Current IO (mA) 3/6 MMDTA143Z Double Silicon PNP Digital Transistor Package Outline SOT-23-6 Dimensions in mm 2.92 ±0.1 0.127 +0.05/-0.02 10 1.6 2.8 ±0.1 ±0.1 1.9±0.1 12 R0.15MAX 0.95±0.1 0.35±0.05 R0.15MAX 0.06 12 ± 0.05 0.65 ±0.1 1.1 ±0.1 10 Ordering Information Device Package Shipping MMDTA143Z SOT-23-6 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Sep-2021 4/6 MMDTA143Z Double Silicon PNP Digital Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Sep-2021 5/6 MMDTA143Z Double Silicon PNP Digital Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23-6 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F 1.55±0.05 3.50±0.05 2.00±0.05 1.10±0.10 4.00±0.10 8±0.10 4.00±0.10 1.75±0.10 Reel (7'') Pin1 Tape (8mm) www.pingjingsemi.com Revision:2.0 Sep-2021 6/6
MMDTA143Z 价格&库存
很抱歉,暂时无法提供与“MMDTA143Z”相匹配的价格&库存,您可以联系我们找货
