MMBTRC106SS
MMBTRC106SS
    PJ(平晶)
    SOT-23
    数字三极管 SOT23 Vi=20V,-5V GI=80 R1,R2=4.7KΩ,47KΩ PD=200mW
MMBTRC106SS 数据手册
MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor SOT-23 Features  With built-in bias resistors  Simplify circuit design  Reduce a quantity of parts and manufacturing process Equivalent Circuit 1.Base 2.Emitter 3.Collector Collector (Output) Base (Input) R1 R2 Emitter (Common) Resistor Values/Marking Code Type R1 (KΩ) R2 (KΩ) Marking Code MMBTRC101SS 4.7 4.7 1BR MMBTRC102SS 10 10 2BR MMBTRC103SS 22 22 3BR MMBTRC104SS 47 47 4BR MMBTRC105SS 2.2 47 5BR MMBTRC106SS 4.7 47 6BR Absolute Maximum Ratings (TA=25℃) Parameter Output Voltage Input Voltage Symbol Value Unit VO 50 V MMBTRC101SS 20,-10 MMBTRC102SS 30,-10 MMBTRC103SS MMBTRC104SS VI 40,-10 40,-10 MMBTRC105SS 12,-5 MMBTRC106SS 20,-5 V Output Current IO 100 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 °C TSTG -55 to +150 °C Storage Temperature Range www.pingjingsemi.com Revision:2.0 Jan-2022 1/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. MMBTRC101SS 30 -- -- MMBTRC102SS 50 -- -- 70 -- -- MMBTRC104SS 80 -- -- MMBTRC105SS 80 -- -- MMBTRC106SS 80 -- -- -- -- 500 MMBTRC101SS -- -- 1.8 MMBTRC102SS -- -- 0.88 -- -- 0.36 MMBTRC104SS -- -- 0.18 MMBTRC105SS -- -- 3.6 MMBTRC106SS -- -- 1.8 -- -- 0.3 MMBTRC101SS -- -- 2 MMBTRC102SS -- -- 2.4 -- -- 3 MMBTRC104SS -- -- 5 MMBTRC105SS -- -- 1.1 MMBTRC106SS -- -- 1.3 1 -- -- 0.5 -- -- -- 200 -- Unit DC Current Gain at VO = 5 V, IO = 10 mA MMBTRC103SS Output Cutoff Current GI IO(OFF) at VO = 50 V -- nA Input Current at VI = 5 V MMBTRC103SS Output Voltage (ON) II VO(ON) at IO = 10 mA, II = 0.5 mA mA V Input Voltage (ON) at VO = 0.2 V, IO = 5 mA MMBTRC103SS VI(ON) V Input Voltage (OFF) at VO = 5 V, IO = 0.1 mA MMBTRC101SS~104SS VI(OFF) MMBTRC105SS~106SS Transition Frequency at VO = 10 V, IO = 5 mA www.pingjingsemi.com Revision:2.0 Jan-2022 fT V MHz 2/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor Typical Characteristic Curves www.pingjingsemi.com Revision:2.0 Jan-2022 3/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor www.pingjingsemi.com Revision:2.0 Jan-2022 4/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor www.pingjingsemi.com Revision:2.0 Jan-2022 5/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBTRC101SS~MMBTRC106SS SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Jan-2022 6/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Jan-2022 7/8 MMBTRC101SS~MMBTRC106SS NPN Digtal Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Jan-2022 8/8
MMBTRC106SS 价格&库存
很抱歉,暂时无法提供与“MMBTRC106SS”相匹配的价格&库存,您可以联系我们找货
