DTC114ESC
DTC114ESC
    PJ(平晶)
    SOT-23
    数字三极管 SOT23-3 Vi=30V,-10V GI=50 R1,R2=10KΩ PD=200mW
DTC114ESC 数据手册
DTC114ESC NPN Digtal Transistor SOT-23-3 Features  With built-in bias resistors  Simplify circuit design  Reduce a quantity of parts and manufacturing process 2 3 Equivalent Circuit 1 Collector (Output) Base (Input) 1.Base 2.Emitter 3.Collector R1 R2 Emitter (Common) Resistor Values/Marking Code Type R1 (KΩ) R2 (KΩ) Marking Code DTC114ESC 10 10 CE Absolute Maximum Ratings (TA=25℃) Parameter Symbol Value Unit Output Voltage VO 50 V Input Voltage VI 30,-10 V Output Current IO 100 mA Maximum Power Dissipation PD 200 mW Junction Temperature TJ 150 °C TSTG -55 to +150 °C Storage Temperature Range www.pingjingsemi.com Revision:2.0 Jan-2022 1/6 DTC114ESC NPN Digtal Transistor Electrical Characteristics (TA=25℃) Parameter DC Current Gain at VO = 5 V, IO = 10 mA Output Cutoff Current at VO = 50 V Input Current at VI = 5 V Output Voltage (ON) at IO = 10 mA, II = 0.5 mA Input Voltage (ON) at VO = 0.2 V, IO = 5 mA Input Voltage (OFF) at VO = 5 V, IO = 0.1 mA Transition Frequency at VO = -10 V, IO = -5 mA www.pingjingsemi.com Revision:2.0 Jan-2022 Symbol Min. Typ. Max. Unit GI 50 -- -- -- IO(OFF) -- -- 500 nA II -- -- 0.88 mA VO(ON) -- -- 0.3 V VI(ON) -- -- 2.4 V VI(OFF) 1 -- -- V fT -- 200 -- MHz 2/6 DTC114ESC NPN Digtal Transistor Typical Characteristic Curves www.pingjingsemi.com Revision:2.0 Jan-2022 3/6 DTC114ESC NPN Digtal Transistor Package Outline SOT-23-3 Dimensions in mm 10 1.6 2.8 ±0.1 0.127 +0.05/-0.02 ±0.1 ±0.1 2.92 12 R0.15MAX 0.95±0.1 0.35±0.05 R0.15MAX 0.06 12 ± 0.05 0.65 ±0.1 1.1 ±0.1 10 Ordering Information Device Package Shipping DTC114ESC SOT-23-3 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Jan-2022 4/6 DTC114ESC NPN Digtal Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Jan-2022 5/6 DTC114ESC NPN Digtal Transistor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23-3 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Jan-2022 6/6
DTC114ESC 价格&库存
很抱歉,暂时无法提供与“DTC114ESC”相匹配的价格&库存,您可以联系我们找货
