MCR100-8SQ
MCR100-8SQ
    PJ(平晶)
    SOT89-3
    可控硅 SOT89 It=0.8A Vtm=1.7V Ih=5mA Vrrm=600V
MCR100-8SQ 数据手册
MCR100 Series Silicon Controlled Rectifiers Features SOT-89  Sensitive gate silicon controlled rectifiers  Reverse blocking thyristors Equivalent Circuit 1.Cathode(K) 2.Anode(A)3.Gate(G) Marking Code : MCR100-4SQ : MCR100-4 MCR100-6SQ : MCR100-6 MCR100-8SQ : MCR100-8 Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Peak Repetitive Off-State Voltage Note1 Symbol MCR100-6SQ Gate Open) MCR100-8SQ On-State RMS Current Unit 200 MCR100-4SQ (TJ = -40°C~110°C, Sine Wave,50 to 60 Hz, Value VDRM,VRRM 400 V 600 IT(RMS) 0.8 A ITSM 8 A I2t 0.415 A2s PGM 0.1 W PG(AV) 0.1 W Peak Gate Current – Forward (Pulse Width ≤ 1 μs) IGM 1 A Peak Gate Voltage – Reverse (Pulse Width ≤ 1 μs) VGRM 5 V TJ -40 to +110 °C TSTG -40 to +150 °C Peak Non-Repetitive Surge Current (1/2 Cycle, Sine Wave, 60 Hz, TJ = 25°C) Circuit Fusing Considerations (t = 8.3ms) Forward Peak Gate Power (Pulse Width ≤ 1 μs) Forward Average Gate Power (t = 8.3ms) Operating Junction Temperature Range Storage Temperature Range Note: 1.VDRM and VRRM for all types can be applied on continous basis. Ratings apply for zero negative gate voltage; however,positive gate voltage shall not be applied concurrent with negative potential on the anode. Blocking voltages shall not be tested with a constant current sourse such that the voltage ratings of the devices are exceeded. www.pingjingsemi.com Revision:2.0 Oct-2021 1/6 MCR100 Series Silicon Controlled Rectifiers Electrical Characteristics (TA=25℃) Parameter Peak Forward or Reverse Blocking Current Note2 at VD = Rated VDRM and VRRM, RGK =1KΩ Peak Forward On-State Voltage Note1 at ITM = 0.8 A Gate Trigger Current Note3 at VAK = 7 V, RL = 100 Ω Holding Current Note2 at VAK = 7 V, Initiating Current = 20 mA Latch Current at VAK = 7 V, Ig = 1 mA TC = 25°C TC = -40°C TC = 25°C TC = -40°C Gate Trigger Voltage Note3 TC = 25°C at VAK = 7 V, RL = 100 Ω TC = -40°C Symbol Value Unit IDRM,IRRM 10 μA VTM 1.7 V IGT 200 μA IH IL VGT 5 10 10 15 0.8 1.2 mA mA V Note: 1.Indicates pulse test width ≤ 1 ms, duty cycle ≤1% 2.RGK = 1 KΩ included in measurement 3.Does not include RGK in measurement www.pingjingsemi.com Revision:2.0 Oct-2021 2/6 MCR100 Series Silicon Controlled Rectifiers VGT Gate Trigger Voltage (V) IGT Gate Trigger Current (μA) Typical Characteristic Curves TJ Junction Temperature (℃) IL Latch Current (μA) IH Holding Current (μA) TJ Junction Temperature (℃) TJ Junction Temperature (℃) TC Case Temperature (℃) IT Instantaneous On-State Current (A) TJ Junction Temperature (℃) IT(RMS) On-State RMS Current (A) www.pingjingsemi.com Revision:2.0 Oct-2021 Maximum TJ =25℃ Maximum TJ =110℃ VT Instantaneous On-State Voltage (V) 3/6 MCR100 Series Silicon Controlled Rectifiers Package Outline SOT-89 Dimensions in mm Ordering Information Device Package Shipping MCR100 Series SOT-89 3,000PCS/Reel&13inches www.pingjingsemi.com Revision:2.0 Oct-2021 4/6 MCR100 Series Silicon Controlled Rectifiers Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Oct-2021 5/6 MCR100 Series Silicon Controlled Rectifiers Package Specifications  The method of packaging 3,000 pcs per reel SOT-89 9,000 pcs per box 3 reels per box 36,000 pcs per carton 4 boxes per carton  Embossed tape and reel data B A T symbol E D F A B C D E F T Value(unit:mm) φ330±1 12.7±0.5 16.5±0.3 φ99.5±0.5 φ13.6±0.3 2.8±0.3 1.9±0.2 C Reel (13'') www.pingjingsemi.com Revision:2.0 Oct-2021 6/6
MCR100-8SQ 价格&库存
很抱歉,暂时无法提供与“MCR100-8SQ”相匹配的价格&库存,您可以联系我们找货
