MAC97A6SC
MAC97A6SC
    PJ(平晶)
    SOT-23
    可控硅 SOT23-3 It=0.6A Vtm=1.9V Ih=10mA Vrrm=400V
MAC97A6SC 数据手册
MAC97A6SC BI-Directional Triode Thyristor SOT-23-3 Features  Reverse Blocking Thyristors  Sensitive Gate Silicon Controlled Rectifiers 2 3 Equivalent Circuit 1 MT2 1.G 2.MT1 3.MT2 Marking Code:97A6 G MT1 Absolute Maximum Ratings (TA=25℃) Parameter Symbol Value Unit Peak Repetitive Off-State Voltage VDRM 400 V On-State RMS Current IT(RMS) 0.6 A ITSM 8 A I2t 0.3 A2s PGM 5 W PG(AV) 0.1 W Peak Non-Repetitive Surge Current (t=20ms) Circuit Fusing Considerations (t = 8.3ms) Forward Peak Gate Power (t = 2 µs max) Forward Average Gate Power ( t = 2 µs max) Peak Gate Current ─ Forward (t = 2 µs max) IGM 1 A Peak Gate Voltage ─ Reverse (t = 2 µs max) VGRM 5 V TJ -40 to +125 °C TSTG -40 to +150 °C Operating Junction Temperature Range Storage Temperature Range www.pingjingsemi.com Revision:2.0 Jan-2022 1/6 MAC97A6SC BI-Directional Triode Thyristor Electrical Characteristics (TA=25℃) Parameter Symbol Typ. Max. Unit VTM 1.4 1.9 V -- 5 -- -5 T2-,G- -- -5 T2+,G+ 0.8 1.2 -0.8 -1.2 -0.8 -1.2 1 10 -1 -10 -- 10 -- -10 -- -10 Peak Forward On-State Voltage at ITM = 0.85 A Gate Trigger Current at VD = 12 V, IT = 0.1 A Gate Trigger Voltage at VD = 12 V, IT = 0.1 A T2+,G+ T2+,G- T2+,GT2+,G+ at VD = 12 V, IGT = 0.06 A T2-,G- at VD = 12 V, IGT = 0.06 A www.pingjingsemi.com Revision:2.0 Jan-2022 VGT T2-,G- Holding Current Latch Current IGT IH T2+,G+ T2+,GT2-,G- IL mA V mA mA 2/6 MAC97A6SC BI-Directional Triode Thyristor Typical Characteristic Curves 3 1 IT(RMS) IT(RMS) (A) f = 50 Hz; Tlead ≤ 50℃ (A) 2.5 0.8 2 0.6 1.5 0.4 1 0.2 0 0.5 0 0 20 40 60 80 100 120 140 Tlead (℃) 2.5 1 10 (A) T2− G− IH(Tj) 2 2 IH(25℃) IGT(25℃) 1.5 1.5 1 1 0.5 0.5 0 -60 -20 20 60 100 0 -60 140 -20 20 60 140 2.0 2.5 Tj = 125℃ IT (A) (A) 1.6 2 Max Tj = 25℃ IL(25℃) Typ 1.5 1.2 1 0.8 0.5 0.4 0 -60 100 Tj (℃) Tj (℃) IL(Tj) tsurge (s) 2.5 T2+ G+ (A) IGT(Tj) 10-2 10-3 -20 20 60 100 Tj (℃) www.pingjingsemi.com Revision:2.0 Jan-2022 140 0 0.5 1 1.5 Max VT (V) 2.0 3/6 MAC97A6SC BI-Directional Triode Thyristor Package Outline SOT-23-3 Dimensions in mm 10 1.6 2.8 ±0.1 0.127 +0.05/-0.02 ±0.1 ±0.1 2.92 12 R0.15MAX 0.95±0.1 0.35±0.05 R0.15MAX 0.06 12 ± 0.05 0.65 ±0.1 1.1 ±0.1 10 Ordering Information Device Package Shipping MAC97A6SC SOT-23-3 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Jan-2022 4/6 MAC97A6SC BI-Directional Triode Thyristor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:2.0 Jan-2022 5/6 MAC97A6SC BI-Directional Triode Thyristor Package Specifications  The method of packaging Cover Tape 3,000 pcs per reel SOT-23-3 Carrier Tape 30,000 pcs per box 10 reels per box 120,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T2 T1 Symbol A B C E F D T1 T2 B C E Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 F Reel (7'') www.pingjingsemi.com Revision:2.0 Jan-2022 6/6
MAC97A6SC 价格&库存
很抱歉,暂时无法提供与“MAC97A6SC”相匹配的价格&库存,您可以联系我们找货
