MM3Z3V6BW
MM3Z3V6BW
    PJ(平晶)
    SOD-323W
    稳压二极管 SOD323W Vr=1V Ir=10μA Vz=3.6V Pd=300mW
MM3Z3V6BW 数据手册
MM3Z2V0BW~MM3Z75BW Silicon Planar Zener Diodes SOD-323W Features  Total power dissipation: 300mW max  Designed for surface mount 2  Wide zener reverse voltage range:2.0V to 75V  Tolerance approximately ±2% 1 1.Cathode 2.Anode Absolute Maximum Ratings at TA = 25 ℃ Parameter Maximum Power Dissipation Thermal Resistance,Junction-to-Ambient Note1 Junction Temperature Storage Temperature Range Symbols Value Unit PD 300 mW RθJA 417 °C/W TJ 150 °C TSTG -55 to +150 °C Note: 1. Thermal resistance from junction to ambient at P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper areas pads. Electrical Characteristics at TA = 25 ℃ Parameter Forward Voltage at IF = 10 mA www.pingjingsemi.com Revision:2.0 Jun-2021 Symbols Max. Unit VF 0.9 V 1/4 MM3Z2V0BW~MM3Z75BW Silicon Planar Zener Diodes Characteristics at TA = 25 ℃ Type Marking MM3Z2V0BW Zener Voltage Range Note1 Code 0B Dynamic IZT VZT at IZT Impedance Reverse Current ZZT at IZT IR at VR Min.(V) Nom.(V) Max.(V) (mA) Max.(Ω) Max.(μA) (V) 1.96 2.0 2.04 5 100 120 0.5 MM3Z2V2BW 0C 2.16 2.2 2.24 5 100 120 0.7 MM3Z2V4BW C1 2.35 2.4 2.45 5 100 120 1 MM3Z2V7BW D1 2.65 2.7 2.75 5 110 120 1 MM3Z3V0BW E1 2.94 3.0 3.06 5 120 50 1 MM3Z3V3BW F1 3.23 3.3 3.37 5 130 20 1 MM3Z3V6BW H1 3.53 3.6 3.67 5 130 10 1 MM3Z3V9BW J1 3.82 3.9 3.98 5 130 5 1 MM3Z4V3BW K1 4.21 4.3 4.39 5 130 5 1 MM3Z4V7BW M1 4.61 4.7 4.79 5 130 2 1 MM3Z5V1BW N1 5 5.1 5.2 5 130 2 1.5 MM3Z5V6BW P1 5.49 5.6 5.71 5 80 1 2.5 MM3Z6V2BW R1 6.08 6.2 6.32 5 50 1 3 MM3Z6V8BW X1 6.66 6.8 6.94 5 30 0.5 3.5 MM3Z7V5BW Y1 7.35 7.5 7.65 5 30 0.5 4 MM3Z8V2BW Z1 8.04 8.2 8.36 5 30 0.5 5 MM3Z9V1BW A2 8.92 9.1 9.28 5 30 0.5 6 MM3Z10BW B2 9.8 10 10.2 5 30 0.1 7 MM3Z11BW C2 10.78 11 11.22 5 30 0.1 8 MM3Z12BW D2 11.76 12 12.24 5 35 0.1 9 MM3Z13BW E2 12.74 13 13.26 5 35 0.1 10 MM3Z15BW F2 14.7 15 15.3 5 40 0.1 11 MM3Z16BW H2 15.68 16 16.32 5 40 0.1 12 MM3Z18BW J2 17.64 18 18.36 5 45 0.1 13 MM3Z20BW K2 19.6 20 20.4 5 50 0.1 15 MM3Z22BW M2 21.56 22 22.44 5 55 0.1 17 MM3Z24BW N2 23.52 24 24.48 5 60 0.1 19 MM3Z27BW P2 26.46 27 27.54 2 70 0.1 21 MM3Z30BW R2 29.4 30 30.60 2 80 0.1 23 MM3Z33BW X2 32.34 33 33.66 2 80 0.1 25 MM3Z36BW Y2 35.28 36 36.72 2 90 0.1 27 MM3Z39BW Z2 38.22 39 39.78 2 100 0.1 30 MM3Z43BW A3 42.14 43 43.86 2 130 0.1 33 MM3Z47BW B3 46.06 47 47.94 2 150 0.1 36 MM3Z51BW C3 49.98 51 52.02 2 180 0.1 39 MM3Z56BW D3 54.88 56 57.12 2 200 0.1 43 MM3Z62BW E3 60.76 62 63.24 2 215 0.1 47 MM3Z68BW F3 66.64 68 69.36 2 240 0.1 52 MM3Z75BW H3 73.5 75 76.5 2 265 0.1 56 Note: 1. VZT is tested with 20ms pulse. www.pingjingsemi.com Revision:2.0 Jun-2021 2/4 MM3Z2V0BW~MM3Z75BW Silicon Planar Zener Diodes Typical Characteristic Curves Transient Thermal Impedance (°C/W) Power Dissipation (W) 0.6 0.5 0.4 0.3 0.2 0.1 0.0 25 50 75 100 125 TA, Ambient Temperature (°C) www.pingjingsemi.com Revision:2.0 Jun-2021 150 175 2000 1000 100 10 0.01 0.1 1 10 100 t, Pulse Duration(sec) 3/4 MM3Z2V0BW~MM3Z75BW Silicon Planar Zener Diodes Package Outline SOD-323W Dimensions in mm E D b A C A1 ∠ALL ROUND L1 E1 A C D E E1 b L1 A1 max 1.1 0.15 1.4 1.8 2.75 0.4 0.45 0.2 min 0.8 0.08 1.2 1.4 2.55 0.25 0.2 max 43 5.9 55 70 108 16 16 min 32 3.1 47 63 100 9.8 7.9 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jun-2021 8 ∠ 9° 4/4
MM3Z3V6BW 价格&库存
很抱歉,暂时无法提供与“MM3Z3V6BW”相匹配的价格&库存,您可以联系我们找货
