BZX84C6V2CA
BZX84C6V2CA
    PJ(平晶)
    SOT-23
    稳压二极管 SOT23 Vr=4V Ir=3μA Vz=6.2V Pd=350mW
BZX84C6V2CA 数据手册
BZX84C...CA Series Silicon Planar Zener Diodes Features SOT-23  Total power dissipation: 350mW max  Package designed for optimal automated board assembly  Small package size for high density applications  Wide zener reverse voltage range:2.0V to 75V Equivalent Circuit 1.Cathode1 2.Cathode2 3.Anode1、 Anode2 3.Anode1、Anode2 1.Cathode1 2.Cathode2 Absolute Maximum Ratings at TA = 25 ℃ Parameter Maximum Power Dissipation Thermal Resistance,Junction-to-Ambient Note1 Junction Temperature Storage Temperature Range Symbols Value Unit PD 350 mW RθJA 357 °C/W TJ 150 °C TSTG -65 to +150 °C Symbols Value Unit VF 0.9 V Note: 1. Alumina = 0.4 X 0.3 X 0.024 in,99.5% Alumina Electrical Characteristics at TA = 25 ℃ Parameter Forward Voltage at IF = 10 mA www.pingjingsemi.com Revision:2.0 Aug-2021 1/4 BZX84C...CA Series Silicon Planar Zener Diodes Electrical Characteristics at TA = 25 ℃ (Ta=25℃, unless otherwise noted Type Marking Zener Voltage Range Note1 Code Dynamic IZT VZT at IZT Impedance Reverse Current ZZT at IZT at IZT IR at VR Min.(V) Nom.(V) Max.(V) (mA) Max.(Ω) (mA) Max.(μA) (V) BZX84C2V4CA 7H 2.2 2.4 2.6 5 100 5 50 1 BZX84C2V7CA 7J 2.5 2.7 2.9 5 100 5 20 1 BZX84C3V0CA MR 2.8 3.0 3.2 5 95 5 10 1 BZX84C3V3CA MX 3.1 3.3 3.5 5 95 5 5 1 BZX84C3V6CA MY 3.4 3.6 3.8 5 90 5 5 1 BZX84C3V9CA MZ 3.7 3.9 4.1 5 90 5 3 1 BZX84C4V3CA NA 4 4.3 4.6 5 90 5 3 1 BZX84C4V7CA NB 4.4 4.7 5 5 80 5 3 2 BZX84C5V1CA NC 4.8 5.1 5.4 5 60 5 2 2 BZX84C5V6CA ND 5.2 5.6 6 5 40 5 1 2 BZX84C6V2CA NE 5.8 6.2 6.6 5 10 5 3 4 BZX84C6V8CA NF 6.4 6.8 7.2 5 15 5 2 4 BZX84C7V5CA NH 7 7.5 7.9 5 15 5 1 5 BZX84C8V2CA NJ 7.7 8.2 8.7 5 15 5 0.7 5 BZX84C9V1CA NK 8.5 9.1 9.6 5 15 5 0.5 6 BZX84C10CA NM 9.4 10 10.6 5 20 5 0.2 7 BZX84C11CA NN 10.4 11 11.6 5 20 5 0.1 8 BZX84C12CA NP 11.4 12 12.7 5 25 5 0.1 8 BZX84C13CA NX 12.4 13 14.1 5 30 5 0.1 8 BZX84C15CA NY 14.3 15 15.8 5 30 5 0.05 10.5 BZX84C16CA NZ 15.3 16 17.1 5 40 5 0.05 11.2 BZX84C18CA PA 16.8 18 19.1 5 45 5 0.05 12.6 BZX84C20CA PB 18.8 20 21.2 5 55 5 0.05 14 BZX84C22CA PC 20.8 22 23.3 5 55 5 0.05 15.4 BZX84C24CA PD 22.8 24 25.6 5 70 5 0.05 16.8 BZX84C27CA PE 25.1 27 28.9 2 80 2 0.05 18.9 BZX84C30CA PF 28 30 32 2 80 2 0.05 21 BZX84C33CA PH 31 33 35 2 80 2 0.05 23.1 BZX84C36CA PJ 34 36 38 2 90 2 0.05 25.2 BZX84C39CA PM 37 39 41 2 130 2 0.05 27.3 BZX84C43CA PN 40 43 46 2 150 2 0.05 30.1 BZX84C47CA PP 44 47 50 2 170 2 0.05 32.9 BZX84C51CA 7K 48 51 54 2 180 2 0.05 35.7 BZX84C56CA 7M 52 56 60 2 200 2 0.05 39.2 BZX84C62CA 7N 58 62 66 2 215 2 0.05 43.4 BZX84C68CA 7P 64 68 72 2 240 2 0.05 47.6 BZX84C75CA 7R 70 75 79 2 255 2 0.05 52.5 Note: 1. VZT is tested with 20ms pulse. www.pingjingsemi.com Revision:2.0 Aug-2021 2/4 BZX84C...CA Series Silicon Planar Zener Diodes Typical Characteristic Curves Temperature Coefficient (mV/℃) Temperature Coefficient (mV/℃) 8 7 6 5 4 3 2 1 0 -1 -2 -3 3 4 5 6 7 8 9 10 11 100 10 1 12 10 100 Nominal Value VZ (V) Zener voltage VZ (v) Forward Current IF (mA) Power Dissipation PD (mW) 220 200 180 160 140 120 5V1 100 80 27V 60 40 20 0 Ambient Temperature TA (℃) www.pingjingsemi.com Revision:2.0 Aug-2021 500 700 900 1100 Forward Voltage VF (mV) 3/4 BZX84C...CA Series Silicon Planar Zener Diodes Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping BZX84C...CA Series SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Aug-2021 4/4
BZX84C6V2CA 价格&库存
很抱歉,暂时无法提供与“BZX84C6V2CA”相匹配的价格&库存,您可以联系我们找货
