BZX84C43
BZX84C43
    PJ(平晶)
    SOT-23
    稳压二极管 SOT23 Vr=30.1V Ir=5μA Vz=43V Pd=350mW
BZX84C43 数据手册
BZX84C Series Silicon Planar Zener Diodes Features SOT-23  Total power dissipation: 350mW max  Package designed for optimal automated board assembly  Small package size for high density applications  Wide zener reverse voltage range:2.0V to 75V Equivalent Circuit 1.Anode 2.NC 3.Cathode 3.Cathode 1.Anode 2.NC Absolute Maximum Ratings at TA = 25 ℃ Parameter Maximum Power Dissipation Thermal Resistance,Junction-to-Ambient Note1 Junction Temperature Storage Temperature Range Symbols Value Unit PD 350 mW RθJA 357 °C/W TJ 150 °C TSTG -65 to +150 °C Note: 1. Alumina = 0.4 X 0.3 X 0.024 in,99.5% Alumina www.pingjingsemi.com Revision:3.0 Jun-2021 1/4 BZX84C Series Silicon Planar Zener Diodes Electrical Characteristics at TA = 25 ℃ (Ta=25℃, unless otherwise noted, VF < 0.9 V at IF = 10 mA) Type Marking Zener Voltage Range Note1 Code Dynamic IZT VZT at IZT Min.(V) Nom.(V) Max.(V) (mA) Impedance Reverse Current ZZT at IZT IR at VR Max.(Ω) Max.(μA) (V) BZX84C2V0 A8 1.8 2 2.15 5 100 120 0.5 BZX84C2V2 B8 2.08 2.2 2.33 5 100 120 0.7 BZX84C2V4 C8 2.2 2.4 2.6 5 100 50 1 BZX84C2V7 D8 2.5 2.7 2.9 5 100 20 1 BZX84C3V0 E8 2.8 3 3.2 5 95 10 1 BZX84C3V3 F8 3.1 3.3 3.5 5 95 5 1 BZX84C3V6 H8 3.4 3.6 3.8 5 90 5 1 BZX84C3V9 Z16 3.7 3.9 4.1 5 90 3 1 BZX84C4V3 K8 4 4.3 4.6 5 90 3 1 BZX84C4V7 M8 4.4 4.7 5 5 80 3 2 BZX84C5V1 N8 4.8 5.1 5.4 5 60 2 2 BZX84C5V6 P8 5.2 5.6 6 5 40 1 2 BZX84C6V2 R8 5.8 6.2 6.6 5 10 3 4 BZX84C6V8 X8 6.4 6.8 7.2 5 15 2 4 BZX84C7V5 Y8 7 7.5 7.9 5 15 1 5 BZX84C8V2 Z8 7.7 8.2 8.7 5 15 0.7 5 BZX84C9V1 A9 8.5 9.1 9.6 5 15 0.5 6 BZX84C10 B9 9.4 10 10.6 5 20 0.2 7 BZX84C11 C9 10.4 11 11.6 5 20 0.1 8 BZX84C12 D9 11.4 12 12.7 5 25 0.1 8 BZX84C13 E9 12.4 13 14.1 5 30 0.1 8 BZX84C15 F9 13.8 15 15.6 5 30 0.05 10.5 BZX84C16 H9 15.3 16 17.1 5 40 0.05 11.2 BZX84C18 J9 16.8 18 19.1 5 45 0.05 12.6 BZX84C20 K9 18.8 20 21.2 5 55 0.05 14 BZX84C22 M9 20.8 22 23.3 5 55 0.05 15.4 BZX84C24 N9 22.8 24 25.6 5 70 0.05 16.8 BZX84C27 P9 25.1 27 28.9 2 80 0.05 18.9 BZX84C30 R9 28 30 32 2 80 0.05 21 BZX84C33 X9 31 33 35 2 80 0.05 23.1 BZX84C36 Y9 34 36 38 2 90 0.05 25.2 BZX84C39 Z9 37 39 41 2 130 0.05 27.3 BZX84C43 A0 40 43 46 2 150 0.05 30.1 BZX84C47 B0 44 47 50 2 170 0.05 32.9 BZX84C51 C0 48 51 54 2 180 0.05 35.7 BZX84C56 D0 52 56 60 2 200 0.05 39.2 BZX84C62 E0 58 62 66 2 215 0.05 43.4 BZX84C68 F0 64 68 72 2 240 0.05 47.6 BZX84C75 H0 70 75 79 2 255 0.05 52.5 Note: 1. VZT is tested with 20ms pulse. www.pingjingsemi.com Revision:3.0 Jun-2021 2/4 BZX84C Series Silicon Planar Zener Diodes Typical Characteristic Curves Temperature Coefficient (mV/℃) Temperature Coefficient (mV/℃) 8 7 6 5 4 3 2 1 0 -1 -2 -3 3 4 5 6 7 8 9 10 11 100 10 1 12 10 100 Nominal Value VZ (V) Zener voltage VZ (v) 220 Forward Current IF (mA) Power Dissipation PD (mW) 200 180 160 140 120 5V1 100 80 27V 60 40 20 0 Ambient Temperature TA (℃) www.pingjingsemi.com Revision:3.0 Jun-2021 500 700 900 1100 Forward Voltage VF (mV) 3/4 BZX84C Series Silicon Planar Zener Diodes Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping BZX84C Series SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:3.0 Jun-2021 4/4
BZX84C43 价格&库存
很抱歉,暂时无法提供与“BZX84C43”相匹配的价格&库存,您可以联系我们找货
