SS12F-PJ~SS120F-PJ
Schottky Barrier Diode
Features
SMAF
Low power loss, high efficiency
For surface mounted applications
1
High forward surge current capability
2
2.Anode
1.Cathode
Marking Code :
SS12F-PJ : SS12
SS14F-PJ : SS14
SS16F-PJ : SS16
SS18F-PJ : SS18
SS110F-PJ : SS110
SS112F-PJ : SS112
SS115F-PJ : SS115
SS120F-PJ : SS120
Absolute Maximum Ratings and Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
SS12F-PJ
SS14F-PJ
Maximum Repetitive Peak Reverse Voltage
VRRM
60
80
100
120
150
200
V
Maximum RMS Voltage
VRMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
VDC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
IF(AV)
1.0
A
IFSM
50
A
SS16F-PJ SS18F-PJ SS110F-PJ SS112F-PJ SS115F-PJ SS120F-PJ
Unit
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
Maximum Instantaneous Forward Voltage at 1 A
VF
0.55
0.70
0.85
0.90
V
0.3
0.2
0.1
mA
10
5
2
Maximum DC Reverse Current
at Rated DC Blocking Voltage
TA = 25 °C
IR
TA = 100 °C
Typical Junction Capacitance Note1
Cj
Typical Thermal Resistance Note2
RθJA
95
°C/W
TJ
-55 to +125
°C
TSTG
-55 to +150
°C
Operating Junction Temperature Range
Storage Temperature Range
80
110
pF
Note:
1.
Measured at 1 MHz and applied reverse voltage of 4 V D.C
2.
P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.pingjingsemi.com
Revision:1.0 Aug-2022
1/3
SS12F-PJ~SS120F-PJ
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
resistive or inductive load
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Typical Characteristic Curves
10 4
10 3
T J =100°C
10 2
T J =75°C
10 1
T J =25°C
10 0
60
80
100
500
1.0
SS12F-PJ/SS14F-PJ
SS16F-PJ
SS18F-PJ/SS112F-PJ
SS115F-PJ/SS120F-PJ
0.1
0.2
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS12F-PJ/SS14F-PJ
SS16F-PJ-SS120F-PJ
10
1.8
15
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
100
10
Reverse Voltage (V)
25
1
1
0.1
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Percent of Rated Peak Reverse Voltage(%)
Junction Capacitance (pF)
Instaneous Forward Current (A)
Case Temperature (°C)
1000
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
2/3
SS12F-PJ~SS120F-PJ
Package Outline
SMAF
Dimensions in mm
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
HE
7°
3/3
很抱歉,暂时无法提供与“SS14F-PJ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18026
- 200+0.14008
- 600+0.11772
