SS110-PJ
SS110-PJ
    PJ(平晶)
    SMA(DO-214AC)
    肖特基势垒二极管 SMA VF=0.85V Vrrm=100V Io=1A Ir=200μA
SS110-PJ 数据手册
SS12-PJ~SS120-PJ Schottky Barrier Rectifiers Features 60$  For surface mount applications 2  High forward surge current capability  Low profile package  Low power loss, high efficiency 1  Metal silicon junction,majority carriers conduction &DWKRGH $QRGH Marking Code : SS12-PJ: SS12 SS14-PJ: SS14 SS16-PJ: SS16 SS18-PJ: SS18 SS110-PJ: SS110 SS112-PJ: SS112 SS115-PJ: SS115 SS120-PJ: SS120 Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbol SS12 -PJ SS14 -PJ SS16 -PJ SS18 -PJ SS110 -PJ SS112 -PJ SS115 -PJ SS120 -PJ Unit Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS Voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) 1.0 A IFSM 25 A Parameter Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) VF Maximum Instantaneous Forward Voltage at 1 A 0.55 0.70 0.85 0.90 V 0.3 0.2 0.1 mA 10 5 2 Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C IR TA = 100 °C Typical Junction Capacitance Note1 Cj Typical Thermal Resistance Note2 RθJA 90 °C/W TJ -55 to +125 °C TSTG -55 to +150 °C Operating Junction Temperature Range Storage Temperature Range 110 80 pF Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V DC. 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.pingjingsemi.com Revision:2.0 Nov-2021 1/3 SS12-PJ~SS120-PJ Schottky Barrier Rectifiers 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Average Forward Current (A) Typical Characteristic Curves 10 4 T J =75°C 10 2 SS12-PJ/SS14-PJ SS16-PJ-SS120-PJ 10 1 T J =25°C 10 0 0 Case Temperature (°C) 40 60 80 100 500 20 10 1.0 SS12-PJ/SS14-PJ SS16-PJ SS18-PJ~SS112-PJ SS115-PJ/SS120-PJ 0.1 T J =25°C 200 100 50 SS12/SS14 20 SS16-SS120 10 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 20 15 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 Number of Cycles at 60Hz www.pingjingsemi.com Revision:2.0 Nov-2021 100 Transient Thermal Impedance( °C /W) 25 1 100 10 Reverse Voltage (V) 30 05 1 0.1 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 20 Percent of Rated Peak Reverse Voltage(%) Junction Capacitance (pF) Instaneous Forward Current (A) T J =100°C 10 3 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 SS12-PJ~SS120-PJ Schottky Barrier Rectifiers Package Outline SMA A A Dimensions in mm c b VM HE g A A D E HE c e g b max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 0.2 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 0.05 max 87 181 106 205 12 63 59 7.9 min 75 157 91 185 6 51 35 2 UNIT mil g e E D mm e A e a www.pingjingsemi.com Revision:2.0 Nov-2021 a 0.3 12 3/3
SS110-PJ 价格&库存
很抱歉,暂时无法提供与“SS110-PJ”相匹配的价格&库存,您可以联系我们找货
