SD103AOE
SD103AOE
    PJ(平晶)
    SOD-523(SC-79)
    肖特基势垒二极管 SOD523 VF=0.6V Vrrm=40V Io=0.35A Ir=5μA
SD103AOE 数据手册
SD103AOE~SD103COE Schottky Barrier Diode SOD-523 Features  Low Forward Voltage 2 1 1.Cathode 2.Anode Marking Code : S4 Absolute Maximum Ratings at TA =25 ℃ Parameter Peak Repetitive Reverse Voltage Symbols SD103AOE Unit 40 SD103BOE Reverse Voltage Value VRRM 30 SD103COE 20 SD103AOE 40 SD103BOE VR V 30 SD103COE V 20 Average Forward Rectified Current IF(AV) 350 mA Non-Repetitive Peak Forward Surge Current at t = 1 s IFSM 2 A Power Dissipation PD 200 mW Junction Temperature TJ 125 °C TSTG -65 to +125 °C Storage Temperature Range Characteristics at TA = 25 ℃ Parameter Symbols Min. Typ. Max. Unit 40 -- -- 30 -- -- 20 -- -- -- -- 5 -- -- 5 -- -- 5 -- -- 0.37 -- -- 0.6 CT -- 50 -- pF Trr -- 10 -- nS Reverse Breakdown Voltage at IR = 10 uA SD103AOE SD103BOE V(BR)R SD103COE V Reverse Leakage Current at VR = 30 V SD103AOE at VR = 20 V SD103BOE at VR = 10 V SD103COE IR µA Forward Voltage at IF = 20 mA VF at IF = 200 mA Total Capacitance at VR = 0 V, f = 1 MHz Reverse Recovery Time at IF = IR = 200 mA, Irr = 0.1 IR, RL = 100 Ω www.pingjingsemi.com Revision:1.0 Jun-2021 V 1/3 SD103AOE~SD103COE Schottky Barrier Diode Typical Characteristic Curves 1000 Forward Current IF (mA) Power Dissipation PD (mW) 300 200 100 100 10 1.0 0.1 0 0.01 0 25 50 75 100 200 300 0 0.5 1.0 Forward Voltage VF (V) Ambient Temperature T a (°C) 100 Total Capacitance CT (pF) f=1MHz 10 1 0.1 0 10 20 30 40 Reverse Voltage VR (V) www.pingjingsemi.com Revision:1.0 Jun-2021 2/3 SD103AOE~SD103COE Schottky Barrier Diode Package Outline SOD-523 Dimensions in mm ALL ROUND C A ∠ HE A bp E D UNIT A bp C D E HE V ∠ mm 0.70 0.60 0.4 0.3 0.135 0.100 1.25 1.15 0.85 0.75 1.7 1.5 0.1 5 www.pingjingsemi.com Revision:1.0 Jun-2021 O 3/3
SD103AOE 价格&库存
很抱歉,暂时无法提供与“SD103AOE”相匹配的价格&库存,您可以联系我们找货
