SB24FL
SB24FL
    PJ(平晶)
    SMF(SOD-123FL)
    肖特基势垒二极管 SOD123FL VF=0.55V Vrrm=40V Io=2A Ir=500μA
SB24FL 数据手册
SB22FL~SB220FL Schottky Barrier Diodes Features SOD-123FL  For surface mount applications  High forward surge current capability 1 2  Low power loss,high efficiency 1.Cathode 2.Anode Marking Code : SB22FL : S22 SB24FL : S24 SB26FL : S26 SB28FL : S28 SB210FL : S210 SB212FL : S212 SB215FL : S215 SB220FL : S220 Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol SB22FL SB24FL SB26FL Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS Voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) SB28FL SB210FL SB212FL SB215FL SB220FL 2.0 Unit A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed IFSM 50 40 A on Rated Load (JEDEC method) Maximum Instantaneous Forward Voltage at 2 A VF 0.55 0.70 0.85 0.95 V Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C IR TA = 100 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Operating Junction Temperature Range Storage Temperature Range Cj 0.5 0.3 5 3 220 80 mA pF RθJA 85 °C/W TJ -55 to +150 °C TSTG -55 to +150 °C Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.pingjingsemi.com Revision:2.0 Jul-2021 1/3 SB22FL~SB220FL Schottky Barrier Diodes Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Typical Characteristic Curves 10 4 T J =75°C 10 2 SB22FL/SB24FL SB26FL-SB220FL 10 1 T J =25°C 10 0 0 Case Temperature (°C) 40 60 80 100 500 20 10 1.0 SB22FL/SB24FL SB26FL/SB28FL SB210FL/SB212FL SB215FL/SB220FL 0.1 T J =25°C 200 100 50 SB22FL/SB24FL 20 SB26FL-SB220FL 10 0.2 0 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 SB210FL-SB220FL 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 Number of Cycles at 60Hz www.pingjingsemi.com Revision:2.0 Jul-2021 100 Transient Thermal Impedance(°C/W) SB22FL- SB28FL 10 100 10 Reverse Voltage (V) 60 50 1 0.1 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 20 Percent of Rated Peak Reverse Voltage(%) Junction Capacitance (pF) Instaneous Forward Current (A) T J =100°C 10 3 200 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 SB22FL~SB220FL Schottky Barrier Diodes Package Outline SOD-123FL Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND VM D E A pad e E Top View mil www.pingjingsemi.com Revision:2.0 Jul-2021 Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g g A pad HE ∠ 7° 3/3
SB24FL 价格&库存
很抱歉,暂时无法提供与“SB24FL”相匹配的价格&库存,您可以联系我们找货
