SB110FL
SB110FL
    PJ(平晶)
    SMF(SOD-123FL)
    肖特基势垒二极管 SOD123FL VF=0.85V Vrrm=100V Io=1A Ir=200μA
SB110FL 数据手册
SB12FL~SB120FL Schottky Barrier Diodes Features SOD-123FL  For surface mount applications  High forward surge current capability 1 2  Low power loss,high efficiency 1.Cathode 2.Anode Marking Code : SB12FL : S12 SB14FL : S14 SB16FL : S16 SB18FL : S18 SB110FL : S110 SB112FL : S112 SB115FL : S115 SB120FL : S120 Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol SB12FL SB14FL SB16FL SB18FL SB110FL SB112FL SB115FL SB120FL Unit Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS Voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) 1.0 A IFSM 25 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) Maximum Instantaneous Forward Voltage at 1 A VF 0.55 0.70 0.85 0.90 V 0.3 0.2 0.1 mA 10 5 2 Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C IR TA = 100 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Operating Junction Temperature Range Storage Temperature Range Cj 110 80 pF RθJA 100 °C/W TJ -55 to +150 °C TSTG -55 to +150 °C Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.pingjingsemi.com Revision:2.0 Jul-2021 1/3 SB12FL~SB120FL Schottky Barrier Diodes 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Average Forward Current (A) Typical Characteristic Curves 10 4 10 3 10 2 10 0 0 10 60 80 100 1.0 SB12FL/SB14FL SB16FL/SB18FL SB110FL/SB112FL SB115FL/SB120FL 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 T J =25°C 200 100 50 10 1.8 SB12FL/SB14FL 20 SB16FL-SB120FL 0.1 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 10 Number of Cycles at 60Hz www.pingjingsemi.com Revision:2.0 Jul-2021 100 Transient Thermal Impedance(°C/W) 25 1 10 1 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 500 20 00 20 Percent of Rated Peak Reverse Voltage(%) Junction Capacitance (pF) Instaneous Forward Current (A) T J =25°C 10 1 Case Temperature (°C) 0.1 T J =100°C 1000 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 SB12FL~SB120FL Schottky Barrier Diodes Package Outline SOD-123FL Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND VM D E A pad e E Top View mil www.pingjingsemi.com Revision:2.0 Jul-2021 Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g g A pad HE ∠ 7° 3/3
SB110FL 价格&库存
很抱歉,暂时无法提供与“SB110FL”相匹配的价格&库存,您可以联系我们找货
