MBR0530WA
MBR0530WA
    PJ(平晶)
    SOD-123W(CFP3)
    肖特基势垒二极管 SOD123W VF=0.43V Vrrm=30V Io=0.5A Ir=μA
MBR0530WA 数据手册
MBR0520WA~MBR0540WA Schottky Barrier Diodes Features SOD-123W  High Conductance  Low Forward Voltage Drop 2  Guard Ring Construction for Transient Protection 1 1.Cathode 2.Anode Marking Code : MBR0520WA:SD MBR0530WA:SE MBR0540WA:SF Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols MBR0520WA MBR0530WA MBR0540WA Units Maximum Repetitive Peak Reverse Voltage VRRM 20 30 40 V Maximum RMS Voltage VRMS 14 21 28 V Maximum DC Blocking Voltage VDC 20 30 40 V Maximum Average Forward Current at TA =25 °C Non-repetitive Peak Forward Surge Current At t=8.3 ms IO 0.5 A IFSM 5.5 A Maximum Instantaneous Forward Voltage at IF=0.1 A VF at IF=0.5 A 0.330 0.375 0.510 0.390 0.430 0.620 75 -- -- -- 20 -- V Maximum DC Reverse Current at Rated DC Blocking Voltage at VR=10 V at VR=15 V IR at VR=20 V 250 -- 10 at VR=30 V -- 130 -- at VR=40 V -- -- 20 μA Typical Thermal Resistance RθJA 500 °C/W Junction Temperature Range TJ -55 to +125 °C Storage Temperature Range TSTG -55 to +150 °C www.pingjingsemi.com Revision:1.0 Oct-2021 1/3 MBR0520WA~MBR0540WA Schottky Barrier Diodes 0.6 0.5 0.4 0.3 0.2 0.1 0.0 25 75 50 100 125 150 Instaneous Reverse Current ( mA) Average Forward Current (A) Typical Characteristic Curves 10 1.0 0.1 MBR0520WA MBR0530WA 0.01 0.001 MBR0540WA 0 Ambient Temperature Ta (°C) 10 20 30 40 50 Reverse Voltage(V) 0.01 0 0.2 Junction Capacitance (pF) V 40 30 0.1 V V 1.0 20 Instaneous Forward Current (A) 500 0.4 0.6 0.8 1.0 100 50 20 10 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Transient Thermal Impedance(°C/W) 200 2000 1000 100 10 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.pingjingsemi.com Revision:1.0 Oct-2021 2/3 MBR0520WA~MBR0540WA Schottky Barrier Diodes Package Outline SOD-123W Dimensions in mm A D b E A1 C ∠ALL ROUND L1 E1 A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT mm mil www.pingjingsemi.com Revision:1.0 Oct-2021 8 ∠ 9° 3/3
MBR0530WA
1. 物料型号:文档列出了三种型号的二极管:MBR0520WA、MBR0530WA和MBR0540WA。
2. 器件简介:这些二极管具有高导通性、低正向电压降和瞬态保护的防护环结构。
3. 引脚分配:文档中提到了阳极和阴极的标记,但没有提供详细的引脚分配图。
4. 参数特性:文档提供了这些二极管的最大额定值和电气特性,包括最大重复峰值反向电压、最大有效值电压、最大直流阻断电压、最大平均正向电流、非重复峰值正向浪涌电流、最大瞬时正向电压、最大直流反向电流和典型热阻。
5. 功能详解:文档包含了二极管的典型特性曲线,展示了在不同条件下的瞬时反向电流、平均正向电流、结电容和瞬时正向电压等参数。
6. 应用信息:文档没有直接提供应用信息,但根据二极管的特性,它们可能用于需要高效率和快速切换的应用。
7. 封装信息:文档提供了SOD-123W封装的详细尺寸,包括最大和最小尺寸。
MBR0530WA 价格&库存
很抱歉,暂时无法提供与“MBR0530WA”相匹配的价格&库存,您可以联系我们找货
