M7-PJ
M7-PJ
    PJ(平晶)
    SMAF
    硅整流器 SMAF VF=1.1V Vrrm=1000V Io=1A Ir=5μA
M7-PJ 数据手册
M1-PJ~M7-PJ Surface Mount General Purpose Silicon Rectifiers Features SMAF  For surface mount applications  Glass passivated chip junction 1  Low profile package 2  Easy to pick and place 2.Anode 1.Cathode Marking Code: M1-PJ:M1 M2-PJ:M2 M3-PJ:M3 M4-PJ:M4 M5-PJ:M5 M6-PJ:M6 M7-PJ:M7 Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols M1-PJ M2-PJ M3-PJ M4-PJ M5-PJ M6-PJ M7-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC =125°C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Maximum Instantaneous Forward Voltage at 1 A IF(AV) 1.0 A IFSM 30 A VF 1.1 V IR 5 μA Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C TA = 125 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Junction Temperature Storage Temperature Range 50 Cj 15 pF RθJA 80 °C/W TJ 150 °C TSTG -55 to +150 °C Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V DC. 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 M1-PJ~M7-PJ Surface Mount General Purpose Silicon Rectifiers Typical Characteristic Curves Instaneous Reverse Current (μA) Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 100 T J =150 °C 10 T J =125 °C T J =100 °C 1.0 T J =75 °C 0.1 T J =25 °C 0.01 175 0 600 100 Junction Capacitance (pF) 1.0 °C TJ = 25 00 =1 TJ =1 25 °C °C 0.5 TJ Instaneous Forward Current (A) 400 0.2 0.1 0.6 800 Instaneous Reverse Voltage (V) Case Temperature (°C) T J =25 °C 10 1 0.7 0.8 0.9 1.0 1.1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surge Current (A) 200 35 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 M1-PJ~M7-PJ Surface Mount General Purpose Silicon Rectifiers Package Outline SMAF Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND V M D E A g Top View mil www.pingjingsemi.com Revision:2.0 Jun-2021 Bottom View A C D E e g HE max 1.2 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 47 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm g pad e E A pad HE ∠ 7° 3/3
M7-PJ 价格&库存
很抱歉,暂时无法提供与“M7-PJ”相匹配的价格&库存,您可以联系我们找货
