M7G-PJ
M7G-PJ
    PJ(平晶)
    SMA(DO-214AC)
    硅整流器 SMA VF=1.1V Vrrm=1000V Io=1A Ir=5μA
M7G-PJ 数据手册
M1G-PJ~M7G-PJ Surface Mount General Purpose Silicon Rectifiers 60$ Features  For surface mount applications 2  Glass Passivated Chip Junction  Low profile package 1 2.Anode 1.Cathode Marking Code: M1G-PJ:M1 M2G-PJ:M2 M3G-PJ:M3 M4G-PJ:M4 M5G-PJ:M5 M6G-PJ:M6 M7G-PJ:M7 Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols M1G-PJ M2G-PJ M3G-PJ M4G-PJ M5G-PJ M6G-PJ M7G-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current IF(AV) 1.0 A IFSM 30 A VF 1.1 V 5 μA Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Maximum Instantaneous Forward Voltage at 1 A Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C IR TA = 125 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Junction Temperature Storage Temperature Range 50 Cj 15 pF RθJA 75 °C/W TJ 150 °C TSTG -55 to +150 °C Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V DC. 2. P.C.B. mounted with 1.0" X 1.0" (2.54X 2.54 cm) copper pad areas. www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 M1G-PJ~M7G-PJ Surface Mount General Purpose Silicon Rectifiers Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 175 Instaneous Reverse Current (μA) Typical Characteristic Curves 100 T J =150°C 10 T J =125°C T J =100°C 1.0 T J =75°C 0.1 T J =25°C 0.01 0 Junction Capacitance (pF) 1.0 C TJ = 2 5° 00 =1 TJ =1 25 °C °C 0.5 TJ Instaneous Forward Current (A) Case Temperature (°C) 0.8 0.9 0.2 0.1 0.6 400 600 800 100 T J =25°C 10 1 0.7 1.0 1.1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 200 Instaneous Reverse Voltage (V) 35 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 M1G-PJ~M7G-PJ Surface Mount General Purpose Silicon Rectifiers Package Outline SMA A A Dimensions in mm c a VM HE e A g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jun-2021 g e A D a 0.3 12 3/3
M7G-PJ 价格&库存
很抱歉,暂时无法提供与“M7G-PJ”相匹配的价格&库存,您可以联系我们找货
