1N4007FL
1N4007FL
    PJ(平晶)
    SMF(SOD-123FL)
    硅整流器 SOD123FL VF=1.1V Vrrm=1000V Io=1A Ir=5μA
1N4007FL 数据手册
1N4001FL~1N4007FL Surface Mount General Purpose Silicon Rectifiers Features SOD-123FL  For surface mount applications  Glass passivated chip junction 1 2  Low profile package  High efficiency  Lead free in comply with EU RoHS 2011/65/EU directive 1.Cathode 2.Anode Marking Code: 1N4001FL:A1 1N4002FL:A2 1N4003FL:A3 1N4004FL:A4 1N4005FL:A5 1N4006FL:A6 1N4007FL:A7 Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols 1N4001FL 1N4002FL 1N4003FL 1N4004FL 1N4005FL 1N4006FL 1N4007FL Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC =125°C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Maximum Instantaneous Forward Voltage at 1 A IF(AV) 1.0 A IFSM 30 A VF 1.1 V IR 5 μA Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25°C TA = 125°C 50 Cj 11 pF RθJA 90 °C/W TJ 150 °C TSTG -55 to +150 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Junction Temperature Storage Temperature Range Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.pingjingsemi.com Revision:2.0 May-2021 1/3 1N4001FL~1N4007FL Surface Mount General Purpose Silicon Rectifiers Typical Characteristic Curves Instaneous Reverse Current (μA) Average Forward Current (A) 1.2 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 T=150 °C J T=125 °C J 10 1.0 T=75 °C J 0.1 T J =25 °C 0.01 1N4007W 0 600 100 Junction Capacitance (pF) 1.0 °C 25 TJ = 10 TJ = 1 50 0°C °C 0.5 TJ= Instaneous Forward Current (A) 400 0.2 0.1 0.5 0.6 0.7 0.8 0.9 800 Instaneous Reverse Voltage (V) Case Temperature (°C) 1.0 1.1 Instaneous Forward Voltage (V) Peak Forward Surge Current (A) 200 T=25 °C J 10 1 0.1 1.0 10 100 Reverse Voltage (V) 35 30 25 20 15 10 05 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 May-2021 2/3 1N4001FL~1N4007FL Surface Mount General Purpose Silicon Rectifiers Package Outline SOD-123FL Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND VM D E A pad e E Top View mil www.pingjingsemi.com Revision:2.0 May-2021 Bottom View A C D E e g EH max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g g A pad HE ∠ 7° 3/3
1N4007FL 价格&库存
很抱歉,暂时无法提供与“1N4007FL”相匹配的价格&库存,您可以联系我们找货
