SMF24A
SMF24A
    PJ(平晶)
    SOD-123FL
    SOD123FL SMT 24V 38.9V
SMF24A 数据手册
SMF Series Surface Mount Transient Voltage Suppressor Features SOD-123FL  Low inductance  Low profile package 1 1.Cathode  Glass passivated junction 2 2.Anode Unipolar Bipolar Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Peak Pulse Power Dissipation on TA=25°C (Note1,2,5) Peak Forward Surge Current Note3 Peak Pulse Current on 10/1000 us waveform Note1 Steady State Power Dissipation Note 4 Typical Thermal Resistance Junction to Ambient Operating Junction Temperature Storage Temperature Range Symbols Value Unit PPPM 200 W 20 A IPPM see Table 1 A PM(AV) 1 W RθJA 180 °C/W TJ 150 °C TSTG -55 to +150 °C IFSM (UNI) Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5mm2 copper pads to each terminal. 3. 8.3ms single half sinewave, or equivalent square wave duty cycle=4 pulses per minutes maximum. 4. lead temperature at TL=75°C 5. Peak pulse power waveform is 10/1000μS. www.pingjingsemi.com Revision:2.0 Jul-2021 1/5 SMF Series Surface Mount Transient Voltage Suppressor Electrical Characteristics Table 1 Ratings at TA = 25℃ ambient temperature unless otherwise specified. Breakdown Test Reverse Stand-off Voltage Current Leakage Voltage Type UNI Reverse BI VBR at IT IT Max. Peak Clamp Pulse Voltage Current IR VC at VRWM at IPP IPP Package SOD-123FL Device Marking Code VRMW Min. Max. V V V mA μA V A UNI BI 5 6.4 7 10 400 9.2 21.7 AE CAE SMF5.0A SMF5.0CA SMF6.0A SMF6.0CA 6 6.67 7.37 10 400 10.3 19.4 AG CAG SMF6.5A SMF6.5CA 6.5 7.22 7.98 10 250 11.2 17.9 AK CAK SMF7.0A SMF7.0CA 7 7.78 8.6 10 100 12 16.7 AM CAM SMF7.5A SMF7.5CA 7.5 8.33 9.21 1 50 12.9 15.5 AP CAP SMF8.0A SMF8.0CA 8 8.89 9.83 1 25 13.6 14.7 AR CAR SMF8.5A SMF8.5CA 8.5 9.44 10.4 1 10 14.4 13.9 AT CAT SMF9.0A SMF9.0CA 9 10 11.1 1 5 15.4 13 AV CAV SMF10A SMF10CA 10 11.1 12.3 1 2.5 17 11.8 AX CAX SMF11A SMF11CA 11 12.2 13.5 1 2.5 18.2 11 AZ CAZ SMF12A SMF12CA 12 13.3 14.7 1 2.5 19.9 10.1 BE CBE SMF13A SMF13CA 13 14.4 15.9 1 1 21.5 9.3 BG CBG SMF14A SMF14CA 14 15.6 17.2 1 1 23.2 8.6 BK CBK SMF15A SMF15CA 15 16.7 18.5 1 1 24.4 8.2 BM CBM SMF16A SMF16CA 16 17.8 19.7 1 1 26 7.7 BP CBP SMF17A SMF17CA 17 18.9 20.9 1 1 27.6 7.2 BR CBR SMF18A SMF18CA 18 20 22.1 1 1 29.2 6.8 BT CBT SMF20A SMF20CA 20 22.2 24.5 1 1 32.4 6.2 BV CBV SMF22A SMF22CA 22 24.4 26.9 1 1 35.5 5.6 BX CBX SMF24A SMF24CA 24 26.7 29.5 1 1 38.9 5.1 BZ CBZ SMF26A SMF26CA 26 28.9 31.9 1 1 42.1 4.8 CE CCE SMF28A SMF28CA 28 31.1 34.4 1 1 45.4 4.4 CG CCG SMF30A SMF30CA 30 33.3 36.8 1 1 48.4 4.1 CK CCK SMF33A SMF33CA 33 36.7 40.6 1 1 53.3 3.8 CM CCM SMF36A SMF36CA 36 40 44.2 1 1 58.1 3.4 CP CCP SMF40A SMF40CA 40 44.4 49.1 1 1 64.5 3.1 CR CCR SMF43A SMF43CA 43 47.8 52.8 1 1 69.4 2.9 CT CCT SMF45A SMF45CA 45 50 55.3 1 1 72.7 2.8 CV CCV SMF48A SMF48CA 48 53.3 58.9 1 1 77.4 2.6 CX CCX SMF51A SMF51CA 51 56.7 62.7 1 1 82.4 2.4 CZ CCZ SMF54A SMF54CA 54 60 66.3 1 1 87.1 2.3 DE CDE SMF58A SMF58CA 58 64.4 71.2 1 1 93.6 2.1 DG CDG SMF60A SMF60CA 60 66.7 73.7 1 1 96.8 1.8 DK CDK SMF64A SMF64CA 64 71.1 78.6 1 1 103 1.7 DM CDM SMF70A SMF70CA 70 77.8 86 1 1 113 1.5 DP CDP SMF75A SMF75CA 75 83.3 92.1 1 1 121 1.4 DR CDR SMF78A SMF78CA 78 86.7 95.8 1 1 126 1.4 DT CDT www.pingjingsemi.com Revision:2.0 Jul-2021 2/5 SMF Series Surface Mount Transient Voltage Suppressor SMF85A SMF85CA 85 94.4 104 1 1 137 1.3 DV CDV SMF90A SMF90CA 90 100 111 1 1 146 1.2 DX CDX SMF100A SMF100CA 100 111 123 1 1 162 1.1 DZ CDZ SMF110A SMF110CA 110 122 135 1 1 177 1 EE CEE SMF120A SMF120CA 120 133 147 1 1 193 0.9 EG CEG SMF130A SMF130CA 130 144 159 1 1 209 0.8 EK CEK SMF150A SMF150CA 150 167 185 1 1 243 0.7 EM CEM SMF160A SMF160CA 160 178 197 1 1 259 0.7 EP CEP SMF170A SMF170CA 170 189 209 1 1 275 0.6 ER CER SMF180A SMF180CA 180 201 222 1 1 292 0.5 ET CET SMF190A SMF190CA 190 211 232 1 1 308 0.5 EV CEV SMF200A SMF200CA 200 224 247 1 1 324 0.5 EX CEX SMF220A SMF220CA 220 246 272 1 1 356 0.5 E22 CE22 SMF250A SMF250CA 250 279 309 1 1 405 0.5 E25 CE25 SMF300A SMF300CA 300 335 371 1 1 486 0.45 E30 CE30 SMF350A SMF350CA 350 391 432 1 1 567 0.4 E35 CE35 SMF400A SMF400CA 400 447 494 1 1 648 0.35 E40 CE40 SMF440A SMF440CA 440 492 543 1 1 713 0.3 E44 CE44 www.pingjingsemi.com Revision:2.0 Jul-2021 3/5 SMF Series Surface Mount Transient Voltage Suppressor Typical Characteristic Curves Fig.1 Fig.2 Peak Pulse Power(PPP) or Current(IPP) Deratingin Percentage% PPPM,Peak Pulse Forward (kW) 10 Non-Repetive Pulse.Wavefom Shown in Figure.3 TA=25°C 1.0 0.1 100 80 60 40 20 0 0.01 1 0.1 10 100 1000 25 10000 td, Pulse Width (us) 50 IFSM,Peaj Forward Surge Current (A) I ppm ,Peak Pulse Current (%) 100 Peak Value Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp Ippm 80 Half Value-Ipp/2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 T,Time (ms) www.pingjingsemi.com Revision:2.0 Jul-2021 150 175 Fig.4 TA=25°C tf=10usec 125 TA, Ambient Temperature (°C) Fig.3 120 100 75 3.0 4.0 30 25 20 15 10 05 TJ=TJmax 8.3ms Single Half JEDEC Method Sinepwave 0 1 10 100 Number of Cycles at 60Hz 4/5 SMF Series Surface Mount Transient Voltage Suppressor Package Outline SOD-123FL Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND VM D E A pad e E Top View mil www.pingjingsemi.com Revision:2.0 Jul-2021 Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g g A pad HE ∠ 7° 5/5
SMF24A 价格&库存
很抱歉,暂时无法提供与“SMF24A”相匹配的价格&库存,您可以联系我们找货
