SMDJ75CA
SMDJ75CA
    PJ(平晶)
    SMC(DO-214AB)
    瞬态电压抑制器 SMC VRWM=75V Vc=121V Pppm=3000W Ippm=24.8A
SMDJ75CA 数据手册
SMDJ Series Surface Mount Transient Voltage Suppressor Features SMC  Low inductance 2  Low profile package 1.Cathode  Glass passivated junction 2.Anode Unipolar 1 Bipolar Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols Value Unit Peak Pulse Power Dissipation on 10/1000us Waveform Note1,Note2 PPPM 3000 W 300 A IPPM see Table 1 A VF 3.5 V PD 6.5 W Typical Thermal Resistance Junction to Lead RθJL 15 °C/W Typical Thermal Resistance Junction to Ambient RθJA 75 °C/W TJ 150 °C TSTG -65 to +150 °C Peak Forward Surge Current,8.3ms Single Half Sine-Wave Note3 Peak Pulse Current on 10/1000us waveform Maximum Instantaneous Forward Voltage at 100 A for Unidirectional Only Power Dissipation on Infinite Heat Sink at TA=50°C Operating Junction Temperature Storage Temperature Range IFSM (UNI) Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2. 2. Mounted on copper pad area of 0.31x0.31" (8.0 x 8.0mm) to each terminal. 3. Measured on 8.3ms single half sine wave or eguivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. www.pingjingsemi.com Revision:2.0 Jul-2022 1/5 SMDJ Series Surface Mount Transient Voltage Suppressor Electrical Characteristics Table 1 Ratings at TA = 25℃ ambient temperature unless otherwise specified. Reverse Breakdown Test Reverse Stand-off Voltage Current Leakage Voltage Type VBR at IT VRMW Min. Max. IT Max. Peak Clamp Pulse Voltage Current IR VC at VRWM at IPP IPP Package SMC Device Marking Code UNI BI V V V mA μA V A UNI BI SMDJ5.0A SMDJ5.0CA 5.0 6.4 7 10 800 9.2 326.1 RDE DDE SMDJ6.0A SMDJ6.0CA 6.0 6.67 7.37 10 800 10.3 291.3 RDG DDG SMDJ6.5A SMDJ6.5CA 6.5 7.22 7.98 10 500 11.2 267.9 RDK DDK SMDJ7.0A SMDJ7.0CA 7.0 7.78 8.6 10 200 12 250 PDM DDM SMDJ7.5A SMDJ7.5CA 7.5 8.33 9.21 1 100 12.9 232.6 PDP DDP SMDJ8.0A SMDJ8.0CA 8.0 8.89 9.83 1 50 13.6 220.6 PDR DDR SMDJ8.5A SMDJ8.5CA 8.5 9.44 10.4 1 20 14.4 208.3 PDT DDT SMDJ9.0A SMDJ9.0CA 9.0 10 11.1 1 10 15.4 194.8 PDV DDV SMDJ10A SMDJ10CA 10.0 11.1 12.3 1 5 17 176.5 PDX DDX SMDJ11A SMDJ11CA 11.0 12.2 13.5 1 2 18.2 164.8 PDZ DDZ SMDJ12A SMDJ12CA 12.0 13.3 14.7 1 2 19.9 150.8 PEE DEE SMDJ13A SMDJ13CA 13.0 14.4 15.9 1 2 21.5 139.5 PEG DEG SMDJ14A SMDJ14CA 14.0 15.6 17.2 1 2 23.2 129.3 PEK DEK SMDJ15A SMDJ15CA 15.0 16.7 18.5 1 2 24.4 123 PEM DEM SMDJ16A SMDJ16CA 16.0 17.8 19.7 1 2 26 115.4 PEP DEP SMDJ17A SMDJ17CA 17.0 18.9 20.9 1 2 27.6 108.7 PER DER SMDJ18A SMDJ18CA 18.0 20 22.1 1 2 29.2 102.7 PET DET SMDJ20A SMDJ20CA 20.0 22.2 24.5 1 2 32.4 92.6 PEV DEV SMDJ22A SMDJ22CA 22.0 24.4 26.9 1 2 35.5 84.5 PEX DEX SMDJ24A SMDJ24CA 24.0 26.7 29.5 1 2 38.9 77.1 PEZ DEZ SMDJ26A SMDJ26CA 26.0 28.9 31.9 1 2 42.1 71.3 PFE DFE SMDJ28A SMDJ28CA 28.0 31.1 34.4 1 2 45.4 66.1 PFG DFG SMDJ30A SMDJ30CA 30.0 33.3 36.8 1 2 48.4 62 PFK DFK SMDJ33A SMDJ33CA 33.0 36.7 40.6 1 2 53.3 56.3 PFM DFM SMDJ36A SMDJ36CA 36.0 40 44.2 1 2 58.1 51.6 PFP DFP SMDJ40A SMDJ40CA 40.0 44.4 49.1 1 2 64.5 46.5 PFR DFR SMDJ43A SMDJ43CA 43.0 47.8 52.8 1 2 69.4 43.2 PFT DFT SMDJ45A SMDJ45CA 45.0 50 55.3 1 2 72.7 41.3 PFV DFV SMDJ48A SMDJ48CA 48.0 53.3 58.9 1 2 77.4 38.8 PFX DFX www.pingjingsemi.com Revision:2.0 Jul-2022 2/5 SMDJ Series Surface Mount Transient Voltage Suppressor SMDJ51A SMDJ51CA 51.0 56.7 62.7 1 2 82.4 36.4 PFZ DFZ SMDJ54A SMDJ54CA 54.0 60 66.3 1 2 87.1 34.4 RGE DGE SMDJ58A SMDJ58CA 58.0 64.4 71.2 1 2 93.6 32.1 PGG DGG SMDJ60A SMDJ60CA 60.0 66.7 73.7 1 2 96.8 31 PGK DGK SMDJ64A SMDJ64CA 64.0 71.1 78.6 1 2 103 29.1 PGM DGM SMDJ70A SMDJ70CA 70.0 77.8 86 1 2 113 26.5 PGP DGP SMDJ75A SMDJ75CA 75.0 83.3 92.1 1 2 121 24.8 PGR DGR SMDJ78A SMDJ78CA 78.0 86.7 95.8 1 2 126 23.8 PGT DGT SMDJ85A SMDJ85CA 85.0 94.4 104 1 2 137 21.9 PGV DGV SMDJ90A SMDJ90CA 90.0 100 111 1 2 146 20.5 PGX DGX SMDJ100A SMDJ100CA 100.0 111 123 1 2 162 18.5 PGZ DGZ SMDJ110A SMDJ110CA 110.0 122 135 1 2 177 16.9 PHE DHE SMDJ120A SMDJ120CA 120.0 133 147 1 2 193 15.5 PHG DHG SMDJ130A SMDJ130CA 130.0 144 159 1 2 209 14.4 PHK DHK SMDJ150A SMDJ150CA 150.0 167 185 1 2 243 12.3 PHM DHM SMDJ160A SMDJ160CA 160.0 178 197 1 2 259 11.6 PHP DHP SMDJ170A SMDJ170CA 170.0 189 209 1 2 275 10.9 PHR DHR www.pingjingsemi.com Revision:2.0 Jul-2022 3/5 SMDJ Series Surface Mount Transient Voltage Suppressor 1000 Non-Repetive Pulse.Wavefom Shown in Figure.3 T A=25°C 100 10 0.31x0.31" (80 x 80mm) Copper pad Area 1.0 10 1 0.1 100 1000 Peak Pulse Power(PPP) or Current(IPP) Deratingin Percentage% PPPM,Peak Pulse Forward (kW) Typical Characteristic Curves 100 80 60 40 20 0 25 10000 td, Pulse Width (us) 120 I ppm Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 175 10000 Bi-directional V= 0V Uni-directional V=0V 1000 Uni-directional @ VR 100 Bi-directional @ VR 10 1 0 1.0 0 2.0 3.0 1 4.0 5 4 3 2 1 25 50 75 100 125 150 175 TA Ambient Temperature (ºC) www.pingjingsemi.com Revision:2.0 Jul-2022 IFSM,Peak Forward Surge Current (A) 6 10 100 1000 VBR Reverse Breakdown Voltage (V) T,Time (ms) P M(AV) Steady Sate Power Dissipation (W) 150 100000 80 0 125 Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp Cj capacitance (pF) I ppm ,Peak Pulse Current (%) Peak Value 100 100 TA, Ambient Temperature (°C) T A =25°C t f =10usec 75 50 360 300 240 180 120 60 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz 4/5 SMDJ Series Surface Mount Transient Voltage Suppressor Package Outline SMC Dimensions in mm E A A1 A C b D L E1 VM A A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jul-2022 5/5
SMDJ75CA 价格&库存
很抱歉,暂时无法提供与“SMDJ75CA”相匹配的价格&库存,您可以联系我们找货
