1N5819W
1N5819W
    PJ(平晶)
    SOD123
    肖特基势垒二极管 SOD123 VF=0.6V Vrrm=40V Io=1A Ir=1000μA
1N5819W 数据手册
1N5817W~1N5819W Schottky Barrier Diodes Features SOD-123  High current capability  Low power loss, high efficiency 2  Guarding for overvoltage protection 1 1.Cathode 2.Anode Marking Code : 1N5817W:SJ 1N5817W:SK 1N5817W:SL Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols 1N5817W 1N5818W 1N5819W Units Maximum Repetitive Peak Reverse Voltage VRRM 20 30 40 V Maximum RMS Voltage VRMS 14 21 28 V Maximum DC Blocking Voltage VDC 20 30 40 V Maximum Average Forward Rectified Current IF(AV) 1.0 A IFSM 25 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC method) Maximum Instantaneous Forward Voltage at 1 A VF at 3 A 0.45 0.55 0.6 0.75 0.875 0.9 V Maximum DC Reverse Current at Rated DC Blocking Voltage at TA = 25°C IR at TA = 100°C 1 mA 10 Typical Junction Capacitance Cj 110 pF Operating Junction Temperature TJ 125 °C TSTG -55 to +125 °C Storage Temperature Range www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 1N5817W~1N5819W Schottky Barrier Diodes 1.2 Instaneous Reverse Current (μA) Average Forward Current (A) Typical Characteristic Curves 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 10 4 10 3 T J =125°C 10 2 T J =75°C 10 1 T J =25°C 10 0 Junction Capacitance (pF) C TJ =2 5° 5°C 12 0.2 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 60 80 100 30 200 100 50 20 10 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 500 0.5 0.1 20 Percent of Rated Peak Reverse Voltage(%) 1.0 TJ = Instaneous Forward Current (A) Case Temperature (°C) 0 8.3 ms Single Half Sine Wave (JEDEC Method) 25 20 15 10 05 00 1 10 100 Number of Cycles at 50Hz www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 1N5817W~1N5819W Schottky Barrier Diodes Package Outline SOD-123 Dimensions in mm A D b E A1 C ∠ALL ROUND L1 E1 SOD-123 mechanical data A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jun-2021 8 ∠ 9° 3/3
1N5819W 价格&库存
很抱歉,暂时无法提供与“1N5819W”相匹配的价格&库存,您可以联系我们找货
