1N5819FL
1N5819FL
    PJ(平晶)
    SMF(SOD-123FL)
    肖特基势垒二极管 SOD123FL VF=0.6V Vrrm=40V Io=1A Ir=1000μA
1N5819FL 数据手册
1N5817FL~1N5819FL Schottky Barrier Diodes SOD-123FL Features  For surface mount applications  High forward surge current capability 1 2  Low power loss,high efficiency  Metal silicon junction,majority carriers conduction 1.Cathode 2.Anode Marking Code : 1N5817FL:12A 1N5818FL:13A 1N5819FL:14A Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols 1N5817FL 1N5818FL 1N5819FL Units Maximum Repetitive Peak Reverse Voltage VRRM 20 30 40 V Maximum RMS Voltage VRMS 14 21 28 V Maximum DC Blocking Voltage VDC 20 30 40 V Maximum Average Forward Rectified Current at TC = 75°C IF(AV) 1.0 A IFSM 25 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC method) Maximum Instantaneous Forward Voltage at 1 A VF at 3 A 0.45 0.55 0.6 0.75 0.875 0.9 V Maximum DC Reverse Current at Rated DC Blocking Voltage at TA = 25°C IR at TA = 100°C 1 mA 10 Typical Junction Capacitance Note1 Cj 110 pF Operating Junction Temperature TJ 150 °C TSTG -55 to +150 °C Storage Temperature Range Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V DC. www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 1N5817FL~1N5819FL Schottky Barrier Diodes Typical Characteristic Curves 10 4 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 75 50 100 125 150 Instaneous Reverse Current (μA) Average Forward Current (A) 1.2 10 3 T J =125 °C 10 2 T J =75 °C 10 1 T J =25 °C 10 0 0 Case Temperature (°C) JunctionCapacitance (pF) =2 5° C TJ 12 5°C 0.5 TJ = Instaneous Forward Current (A) 40 60 80 100 500 1.0 0.2 200 100 50 20 10 0.1 0 0.1 0.2 0.4 0.3 0.5 0.6 0.7 30 0.1 1 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surge Current (A) 20 Percent of Rated Peak Reverse Voltage(%) 8.3 ms Single Half Sine Wave (JEDEC Method) 25 20 15 10 05 00 1 10 100 Number of Cycles at 50Hz www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 1N5817FL~1N5819FL Schottky Barrier Diodes Package Outline SOD-123FL Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND VM D E A pad e E Top View mil www.pingjingsemi.com Revision:2.0 Jun-2021 Bottom View A C D E e g EH max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g g A pad HE ∠ 7° 3/3
1N5819FL 价格&库存
很抱歉,暂时无法提供与“1N5819FL”相匹配的价格&库存,您可以联系我们找货
