SMAJ12CA
SMAJ12CA
    PJ(平晶)
    SMA
    TVS二极管 VRWM=12V VBR(Min)=13.3V VC=19.9V IPP=20.1A Ppp=400W SMA
SMAJ12CA 数据手册
SMAJ Series Surface Mount Transient Voltage Suppressor Features SMA  Low inductance  Low profile package 2 1.Cathode  Glass passivated junction 2.Anode Unipolar 1 Bipolar Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbols Value Unit PPPM 400 W 60 A IPPM see Table 1 A Contact VESD1 ±30 Air VESD2 ±30 RθJA 30 °C/W TJ 150 °C TSTG -65 to +150 °C Peak Pulse Power Dissipation on TA=25°C (Note1,2,3) Peak Forward Surge Current at 8.3 ms IFSM Single Half Sine Wave Superimposed on Rated Load Peak Pulse Current on 10/1000 us waveform Note1 ESD Voltage per IEC6100-4-2 Typical Thermal Resistance Junction to Ambient Note2 Operating Junction Temperature Storage Temperature Range (UNI) kV Note: 1. Non-repetitive current pulse, per Fig.3 and derated above TA = 25°C per Fig. 2. 2. Mounted on 5mm2 copper pads to each terminal. 3. Peak pulse power waveform is 10/1000μS. www.pingjingsemi.com Revision:2.0 Jul-2021 1/5 SMAJ Series Surface Mount Transient Voltage Suppressor Electrical Characteristics Table 1 Ratings at TA = 25℃ ambient temperature unless otherwise specified. Breakdown Test Reverse Stand-off Voltage Current Leakage Voltage Type UNI Reverse BI VBR at IT IT Max. Peak Clamp Pulse Voltage Current IR VC at VRWM at IPP V A VRMW Min. Max. V V V mA μA IPP Package SMA Device Marking Code UNI BI SMAJ5.0A SMAJ5.0CA 5 6.4 7 10 800 9.2 43.5 AE WE SMAJ6.0A SMAJ6.0CA 6 6.67 7.37 10 800 10.3 38.8 AG WG SMAJ6.5A SMAJ6.5CA 6.5 7.22 7.98 10 500 11.2 35.7 AK WK SMAJ7.0A SMAJ7.0CA 7 7.78 8.6 10 200 12 33.3 AM WM SMAJ7.5A SMAJ7.5CA 7.5 8.33 9.21 1 100 12.9 31 AP WP SMAJ8.0A SMAJ8.0CA 8 8.89 9.83 1 50 13.6 29.4 AR WR SMAJ8.5A SMAJ8.5CA 8.5 9.44 10.4 1 20 14.4 27.8 AT WT SMAJ9.0A SMAJ9.0CA 9 10 11.1 1 10 15.4 26 AV WV SMAJ10A SMAJ10CA 10 11.1 12.3 1 5 17 23.5 AX WX SMAJ11A SMAJ11CA 11 12.2 13.5 1 1 18.2 22 AZ WZ SMAJ12A SMAJ12CA 12 13.3 14.7 1 1 19.9 20.1 BE XE SMAJ13A SMAJ13CA 13 14.4 15.9 1 1 21.5 18.6 BG XG SMAJ14A SMAJ14CA 14 15.6 17.2 1 1 23.2 17.2 BK XK SMAJ15A SMAJ15CA 15 16.7 18.5 1 1 24.4 16.4 BM XM SMAJ16A SMAJ16CA 16 17.8 19.7 1 1 26 15.4 BP XP SMAJ17A SMAJ17CA 17 18.9 20.9 1 1 27.6 14.5 BR XR SMAJ18A SMAJ18CA 18 20 22.1 1 1 29.2 13.7 BT XT SMAJ20A SMAJ20CA 20 22.2 24.5 1 1 32.4 12.3 BV XV SMAJ22A SMAJ22CA 22 24.4 26.9 1 1 35.5 11.3 BX XX SMAJ24A SMAJ24CA 24 26.7 29.5 1 1 38.9 10.3 BZ XZ SMAJ26A SMAJ26CA 26 28.9 31.9 1 1 42.1 9.5 CE YE SMAJ28A SMAJ28CA 28 31.1 34.4 1 1 45.4 8.8 CG YG SMAJ30A SMAJ30CA 30 33.3 36.8 1 1 48.4 8.3 CK YK SMAJ33A SMAJ33CA 33 36.7 40.6 1 1 53.3 7.5 CM YM SMAJ36A SMAJ36CA 36 40 44.2 1 1 58.1 6.9 CP YP SMAJ40A SMAJ40CA 40 44.4 49.1 1 1 64.5 6.2 CR YR SMAJ43A SMAJ43CA 43 47.8 52.8 1 1 69.4 5.8 CT YT SMAJ45A SMAJ45CA 45 50 55.3 1 1 72.7 5.5 CV YV SMAJ48A SMAJ48CA 48 53.3 58.9 1 1 77.4 5.2 CX YX SMAJ51A SMAJ51CA 51 56.7 62.7 1 1 82.4 4.9 CZ YZ SMAJ54A SMAJ54CA 54 60 66.3 1 1 87.1 4.6 RE ZE SMAJ58A SMAJ58CA 58 64.4 71.2 1 1 93.6 4.3 RG ZG SMAJ60A SMAJ60CA 60 66.7 73.7 1 1 96.8 4.1 RK ZK SMAJ64A SMAJ64CA 64 71.1 78.6 1 1 103 3.9 RM ZM SMAJ70A SMAJ70CA 70 77.8 86 1 1 113 3.5 RP ZP SMAJ75A SMAJ75CA 75 83.3 92.1 1 1 121 3.3 RR ZR www.pingjingsemi.com Revision:2.0 Jul-2021 2/5 SMAJ Series Surface Mount Transient Voltage Suppressor SMAJ78A SMAJ78CA 78 86.7 95.8 1 1 126 3.2 RT ZT SMAJ85A SMAJ85CA 85 94.4 104 1 1 137 2.9 RV ZV SMAJ90A SMAJ90CA 90 100 111 1 1 146 2.7 RX ZX SMAJ100A SMAJ100CA 100 111 123 1 1 162 2.5 RZ ZZ SMAJ110A SMAJ110CA 110 122 135 1 1 177 2.3 SE VE SMAJ120A SMAJ120CA 120 133 147 1 1 193 2.1 SG VG SMAJ130A SMAJ130CA 130 144 159 1 1 209 1.9 SK VK SMAJ150A SMAJ150CA 150 167 185 1 1 243 1.6 SM VM SMAJ160A SMAJ160CA 160 178 197 1 1 259 1.5 SP VP SMAJ170A SMAJ170CA 170 189 209 1 1 275 1.5 SR VR SMAJ180A SMAJ180CA 180 201 222 1 1 292 1.4 ST VT SMAJ200A SMAJ200CA 200 224 247 1 1 324 1.2 SV VV SMAJ220A SMAJ220CA 220 246 272 1 1 356 1.1 SX VX SMAJ250A SMAJ250CA 250 279 309 1 1 405 1 SZ VZ SMAJ300A SMAJ300CA 300 335 371 1 1 486 0.8 TE UE SMAJ350A SMAJ350CA 350 391 432 1 1 567 0.7 TG UG SMAJ400A SMAJ400CA 400 447 494 1 1 648 0.6 TK UK SMAJ440A SMAJ440CA 440 492 543 1 1 713 0.6 TM UM www.pingjingsemi.com Revision:2.0 Jul-2021 3/5 SMAJ Series Surface Mount Transient Voltage Suppressor Typical Characteristic Curves Fig.2 100 Non-Repetive e ulse.Wavefom Shown in Figure.3 T A=25°C 10 1.0 Mounted on 5.0mm Copper Land Areas 0.1 0.1 10 1 100 1000 10000 Peak Pulse Power(PPP) or Current(IPP) Deratingin Percentage% PPPM,Peak Pulse Forward (kW) Fig.1 100 80 60 40 20 0 25 td, Pulse Width (us) 50 Pulse Width (td) is Defined as the Point where the Peak. Current Decayst to 50% of Ipp alue I ppm 80 Half Value-I pp /2 60 10/1000usec Waveform as Defined bye R.E.A. 40 20 0 0 1.0 2.0 T,Time (ms) www.pingjingsemi.com Revision:2.0 Jul-2021 3.0 4.0 IFSM,Peaj Forward Surge Current (A) I ppm ,Peak Pulse Current (%) Peak k 100 125 150 175 Fig.4 T A =25°C t f =10usec 100 TA, Ambient Temperature (°C) Fig.3 120 75 60 50 40 30 20 10 T J=T Jmax 8.3ms Single Half Sinepwave JEDEC Method 0 1 10 100 Number of Cycles at 60Hz 4/5 SMAJ Series Surface Mount Transient Voltage Suppressor Package Outline SMA A A Dimensions in mm c a b VM e A HE g e E A D E HE c e g b max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 0.2 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 0.05 max 87 181 106 205 12 63 59 7.9 min 75 157 91 185 6 51 35 2 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jul-2021 g e A D a 0.3 12 5/5
SMAJ12CA 价格&库存
很抱歉,暂时无法提供与“SMAJ12CA”相匹配的价格&库存,您可以联系我们找货
