UM10B-PJ
UM10B-PJ
    PJ(平晶)
    UMB
    桥式整流器UMB Vrrm=1000V Ir=30μA Io=0.8A
UM10B-PJ 数据手册
UM1B-PJ~UM10B-PJ Surface Mount Glass Passivated Bridge Rectifiers UMB Features  Glass Passivated Chip Junction  Reverse Voltage - 100 to 1000V 3 4  High Surge Current Capability 2 1  Designed for Surface Mount Application 1.Input Pin(~) 3.Output Anode (+) 2.Input Pin(~) 4.Output Cathode (-) Marking Code: UM1B-PJ:UM1B UM2B-PJ:UM2B UM4B-PJ:UM4B UM6B-PJ:UM6B UM8B-PJ:UM8B UM10B-PJ:UM10B Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols UM1B-PJ UM2B-PJ UM4B-PJ UM6B-PJ UM8B-PJ UM10B-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 100 200 400 600 800 1000 V Maximum Average Rectified Output Current at TC =125°C IO 0.8 A IFSM 25 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) Maximum Forward Voltage IF =0.4A IF =0.8A Maximum DC Reverse Current TA =25°C at Rated DC Blocking Voltage TA =125°C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Junction Temperature Storage Temperature Range VF IR 1.0 1.1 3 30 V μA Cj 13 pF RθJA 110 °C/W TJ 150 °C TSTG -55 to +150 °C Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. www.pingjingsemi.com Revision:2.0 Jul-2022 1/3 UM1B-PJ~UM10B-PJ Surface Mount Glass Passivated Bridge Rectifiers 1.0 Instaneous Reverse Current (μA) Average Rectified Output Current (A) Typical Characteristic Curves 0.8 0.6 0.4 0.2 Resistive or Inductive 0.0 25 50 Load 75 100 125 150 175 100 TJ=125°C 10 1.0 TJ=25°C 0.1 Junction Capacitance (pF) Instaneous Forward Current (A) TJ=25°C 1.0 0.1 0.01 pulse with 300μs 1% duty cycle 0.0 0.5 1.0 1.5 2.0 40 60 80 100 120 140 100 TJ=25°C 10 1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 10 00 30 20 10 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 Jul-2022 2/3 UM1B-PJ~UM10B-PJ Surface Mount Glass Passivated Bridge Rectifiers Package Outline UMB Dimensions in mm C A ∠ALL ROUND HE VM d A E g e D e g A C D E HE g d e max 1.2 0.20 3.8 4.0 5.1 0.82 2.7 0.70 min 1.0 0.12 3.4 3.6 4.6 0.51 2.3 0.51 max 47 7.9 150 157 201 32 106 28 min 39 4.7 134 142 181 20 91 20 UNIT ∠ mm 7° mil www.pingjingsemi.com Revision:2.0 Jul-2022 3/3
UM10B-PJ
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并将其转换为电信号。
3. 引脚分配:EL817共有3个引脚,分别为VCC、OUT和GND。
4. 参数特性:工作电压范围为3V至5.5V,工作频率为30kHz至60kHz。
5. 功能详解:EL817能够接收红外信号,并将其转换为电信号输出。
6. 应用信息:EL817广泛应用于电视、空调等家用电器的红外遥控。
7. 封装信息:EL817采用SOP-8封装。
UM10B-PJ 价格&库存
很抱歉,暂时无法提供与“UM10B-PJ”相匹配的价格&库存,您可以联系我们找货
