MB6S-PJ
MB6S-PJ
    PJ(平晶)
    MBS
    桥式整流器 MBS Vrrm=600V Ir=40μA Io=0.8A
MB6S-PJ 数据手册
MB1S-PJ~MB10S-PJ Surface Mount Glass Passivated Bridge Rectifiers MBS Features  Glass Passivated Chip Junction 3  Reverse Voltage - 100 to 1000 V 4  High Surge Current Capability 2 1  Designed for Surface Mount Application 1.Input Pin(~) 3.Output Anode(+) 2.Input Pin(~) 4.Output Cathode (-) Marking Code: MB1S-PJ:MB1S MB2S-PJ:MB2S MB4S-PJ:MB4S MB6S-PJ:MB6S MB8S-PJ:MB8S MB10S-PJ:MB10S Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols MB1S-PJ MB2S-PJ MB4S-PJ MB6S-PJ MB8S-PJ MB10S-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 100 200 400 600 800 1000 V Maximum Average Rectified Output Current at TC =125°C IO 0.8 A IFSM 30 A VF 1.0 V Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) Maximum Instantaneous Forward Voltage at 0.4 A at 0.8 A 1.1 Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C IR TA = 125 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 Junction Temperature Storage Temperature Range 5 μA 40 Cj 13 RθJA 90 RθJC 32 TJ 150 °C TSTG -55 to +150 °C pF °C/W Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 MB1S-PJ~MB10S-PJ Surface Mount Glass Passivated Bridge Rectifiers 1.2 Instaneous Reverse Current (μA) Average Rectified Output Current (A) Typical Characteristic Curves 1.0 0.8 0.6 0.4 0.2 0.0 25 50 75 100 125 150 175 100 T J =125 °C 10 1.0 T J =25 °C 0.1 JunctionCapacitance (pF) Instaneous Forward Current (A) 0.1 pulse with 300μs 1% duty cycle 0.0 0.5 1.0 1.5 2.0 60 80 100 120 140 Reverse Voltage (%) 10 1 T J =25 °C 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surge Current (A) 40 100 T J =25 °C 1.0 0.01 20 percent of Rated Peak Case Temperature (°C) 10 00 40 30 20 10 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 MB1S-PJ~MB10S-PJ Surface Mount Glass Passivated Bridge Rectifiers Package Outline MBS Dimensions in mm A ∠ALL ROUND C a L1 L d HE e D e E MBS mechanical data A C D E HE d e L L1 a max 2.6 0.22 5.0 4.1 7.0 2.7 0.7 1.7 1.1 0.2 min 2.2 0.15 4.5 3.6 6.4 2.3 0.5 1.3 0.5 max 102 8.7 197 161 276 106 28 67 43 min 94 5.9 177 142 252 91 20 51 20 UNIT ∠ mm 7° 8 mil www.pingjingsemi.com Revision:2.0 Jun-2021 3/3
MB6S-PJ 价格&库存
很抱歉,暂时无法提供与“MB6S-PJ”相匹配的价格&库存,您可以联系我们找货
