MMBD7000
MMBD7000
    PJ(平晶)
    SOT-23
    开关二极管 SOT23 Vrrm=100V Vf=75V Ir=0.001μA Pd=350mW
MMBD7000 数据手册
MMBD7000 Silicon Epitaxial Planar Switching Diode 627 )HDWXUHV  Dual Switching Diode  Fast Switching Speed Equivalent Circuit 1.Anode1 2.Cathode2 3.Cathode1、 Anode2 3.Cathode1、Anode2 Marking Code : B7 1.Anode1 2.Cathode2 $EVROXWH0D[LPXP5DWLQJV 7$ ℃ Parameter Symbol Value Unit VRRM 100 V VR 75 V Average Rectified Forward Current IF(AV) 200 mA Non-Repetitive Peak Forward Surge Current at t=10ms IFSM 2 A Maximum Power Dissipation PD 350 mW Junction Temperature TJ 150 °C TSTG -50 to +150 °C Maximum Repetitive Peak Reverse Voltage Reverse Voltage Storage Temperature Range (OHFWULFDO&KDUDFWHULVWLFV 7$ ℃  Parameter Symbol Min. Max. Unit 0.55 0.7 0.67 0.82 0.75 1.1 V(BR)R 100 -- V IR -- 1 nA -- 3 Cj -- 2 pF Trr -- 4 nS Forward Voltage at IF = 1 mA at IF = 10 mA VF at IF = 100 mA Reverse Breakdown Voltage at IR = 100 µA V Reverse Current at VR = 50 V at VR = 100 V Typical Junction Capacitance at VR = 0 V, f = 1 MHz Maximum Reverse Recovery Time at IF = IR =10 mA,IRR = 1mA, RL = 100Ω www.pingjingsemi.com Revision:2.0 Jun-2021  MMBD7000 Silicon Epitaxial Planar Switching Diode Typical Characteristic Curves 10000 200 Pulsed Pulsed 100 Ta=100C Reverse Current IR (nA) a C =1 00  C 10 T a =2 5 T Forward Current IF (mA) 1000 1 100 Ta=25C 10 0.1 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1 1.1 0 20 Forward Voltage VF (V) 40 60 80 100 Reverse Voltage VR (V) 1.4 400 Ta=25C 1.3 Power Dissipation PD (mW) Capacitance Between Terminals CT (pF) f=1MHz 1.2 1.1 1.0 0 4 8 12 Reverse Voltage VR (V) www.pingjingsemi.com Revision:2.0 Jun-2021 16 20 300 200 100 0 0 25 50 75 100 125 150 Ambient Temperature TA (℃) 2/3 MMBD7000 Silicon Epitaxial Planar Switching Diode Package Outline SOT-23 Dimensions in mm Ordering Information Device Package Shipping MMBD7000 SOT-23 3,000PCS/Reel&7inches www.pingjingsemi.com Revision:2.0 Jun-2021 3/3
MMBD7000 价格&库存
很抱歉,暂时无法提供与“MMBD7000”相匹配的价格&库存,您可以联系我们找货
