US1M-PJ
US1M-PJ
    PJ(平晶)
    SMA(DO-214AC)
    快/超快二极管 SMA Vrrm=1000V Vf=1.65V Ir=5μA
US1M-PJ 数据手册
US1A-PJ~US1M-PJ Surface Mount Ultrafast Recovery Rectifiers 60$ Features  For surface mount applications 2  Glass passivated chip junction  Low profile package  High efficiency 1  Lead free in comply with EU RoHS 2011/65/EU directive 1.Cathode 2.Anode Marking Code: US1A-PJ:US1A US1B-PJ:US1B US1D-PJ:US1D US1G-PJ:US1G US1J-PJ:US1J US1K-PJ:US1K US1M-PJ:US1M Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols US1A-PJ US1B-PJ US1D-PJ US1G-PJ US1J-PJ US1K-PJ US1M-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC =125 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load IF(AV) 1.0 A IFSM 30 A VF Maximum Instantaneous Forward Voltage at 1 A 1.0 1.3 1.65 V Maximum DC Reverse Current at Rated DC Blocking Voltage IR TA = 25 °C 5 TA = 125 °C μA 100 Cj 15 pF Typical Thermal Resistance Note2 RθJA 75 °C/W Maximum Reverse Recovery Time Note3 Trr Junction Temperature TJ 150 °C TSTG -55 to +150 °C Typical Junction Capacitance Note1 Storage Temperature Range 50 75 nS Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 3.Measured with IF=0.5A,IR=1A ,Irr=0.25A. www.pingjingsemi.com Revision:2.0 May-2021 1/3 US1A-PJ~US1M-PJ Surface Mount Ultrafast Recovery Rectifiers 1.2 1.0 0.8 0.6 0.4 0.2 Single Phase Half-wave 60 Hz Resistive Or Inductive Load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Forward Current (A) Typical Characteristic Curves 100 TJ=125°C 10 1.0 TJ=25°C 0.1 00 10 T J =25°C US1A-PJ~US1D-PJ US1G-PJ 0.1 US1J-PJ~US1M-PJ 0.01 0.001 0 0.5 1.0 1.5 2.0 Instaneous Forward Voltage (V) www.pingjingsemi.com Revision:2.0 May-2021 40 60 80 100 120 140 Percent of Rated Peak Reverse Voltage (%) Peak Forward Surge Current (A) Instaneous Forward Current (A) Case Temperature (°C) 20 2.5 40 35 30 25 20 15 10 05 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles 2/3 US1A-PJ~US1M-PJ Surface Mount Ultrafast Recovery Rectifiers Package Outline SMA A A Dimensions in mm c a b VM e A HE g e E A D E HE c e g b max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 0.2 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 0.05 max 87 181 106 205 12 63 59 7.9 min 75 157 91 185 6 51 35 2 UNIT mm mil g e A D www.pingjingsemi.com Revision:2.0 May-2021 a 0.3 12 3/3
US1M-PJ 价格&库存
很抱歉,暂时无法提供与“US1M-PJ”相匹配的价格&库存,您可以联系我们找货
