ES2J-PJ
ES2J-PJ
    PJ(平晶)
    SMA(DO-214AC)
    快/超快二极管 SMA Vrrm=600V Vf=1.68V Ir=5μA
ES2J-PJ 数据手册
ES2A-PJ~ES2J-PJ Surface Mount Superfast Recovery Rectifiers Features 60$  For surface mount applications 2  Glass passivated chip junction  Superfast reverse recovery time 1 1.Cathode 2.Anode Marking Code: ES2A-PJ:ES2A ES2B-PJ:ES2B ES2C-PJ:ES2C ES2D-PJ:ES2D ES2E-PJ:ES2E ES2G-PJ:ES2G ES2J-PJ:ES2J Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols ES2A-PJ ES2B-PJ ES2C-PJ ES2D-PJ ES2E-PJ ES2G-PJ ES2J-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current at TC =125 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Maximum Instantaneous Forward Voltage at 2 A IF(AV) 2.0 A IFSM 50 A VF 1.0 1.25 1.68 V Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C IR TA = 125 °C 5 μA 100 Cj 40 pF Typical Thermal Resistance Note2 RθJA 60 °C/W Maximum Reverse Recovery Time Note3 Trr 35 nS Junction Temperature TJ 150 °C TSTG -55 to +150 °C Typical Junction Capacitance Note1 Storage Temperature Range Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 1.0" X 1.0" (2.54 X 2.54 cm) copper pad areas. 3. Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 ES2A-PJ~ES2J-PJ Surface Mount Superfast Recovery Rectifiers Typical Characteristic Curves 50 ohm Noninductive t rr 10 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 10ns/div Set time Base for 10ns/div 3.0 300 I R - Reverse Current (μA) Average Forward Current (A) Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 100 T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75 100 125 150 175 20 0 60 80 100 10 T J =25°C 1.0 ES2A-PJ~ES2D-PJ ES2E-PJ/ES2G-PJ 0.1 ES2J-PJ 0.01 T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.001 0 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 % of PIV.Volts Junction Capacitance (pF) Instaneous Forward Current (A) Case Temperature (°C) 0.1 1.0 10 100 Reverse Voltage (V) 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 ES2A-PJ~ES2J-PJ Surface Mount Superfast Recovery Rectifiers Package Outline SMA A A Dimensions in mm c a VM HE e A g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jun-2021 g e A D a 0.3 12 3/3
ES2J-PJ 价格&库存
很抱歉,暂时无法提供与“ES2J-PJ”相匹配的价格&库存,您可以联系我们找货
