RS2M-PJ
RS2M-PJ
    PJ(平晶)
    SMA(DO-214AC)
    快/超快二极管 SMA Vrrm=1000V Vf=1.3V Ir=5μA
RS2M-PJ 数据手册
RS2A-PJ~RS2M-PJ Surface Mount Fast Recovery Rectifiers Features 60$  For surface mount applications 2  Glass passivated chip junction  Fast reverse recovery time  Low profile package 1 2.Anode 1.Cathode Marking Code: RS2A-PJ:RS2A RS2B-PJ:RS2B RS2D-PJ:RS2D RS2G-PJ:RS2G RS2J-PJ:RS2J RS2K-PJ:RS2K RS2M-PJ:RS2M Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols RS2A-PJ RS2B-PJ RS2D-PJ RS2G-PJ RS2J-PJ RS2K-PJ RS2M-PJ Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC =125 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Maximum Instantaneous Forward Voltage at 2A IF(AV) 2.0 A IFSM 50 A VF 1.3 V IR 5 μA Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C TA = 125 °C Typical Junction Capacitance Note1 Typical Thermal Resistance Note2 100 Cj 22 RθJA 65 RθJC 20 pF °C/W Maximum Reverse Recovery Time Note3 Trr Junction Temperature TJ 150 °C TSTG -55 to +150 °C Storage Temperature Range 150 250 500 nS Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 3. Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A www.pingjingsemi.com Revision:2.0 Jun-2021 1/3 RS2A-PJ~RS2M-PJ Surface Mount Fast Recovery Rectifiers 3.0 Instaneous Reverse Current (μA) Average Forward Current (A) Typical Characteristic Curves 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 1.0 T J =25°C 0.1 T J =25°C 1.0 0.1 0.01 0.0 pulse with 300μs 1% duty cycle 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 00 20 40 60 80 100 120 140 Percent of Rated Peak Reverse Voltage (%) Junction Capacitance (pF) Instaneous Forward Current (A) Case Temperature (°C) 10 T J =125°C 10 T J =25°C 100 10 1 T J=25°C f = 1.0MHz V sig = 50mV p-p 0.1 1.0 10 100 Reverse Voltage (V) 60 50 40 30 20 10 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles www.pingjingsemi.com Revision:2.0 Jun-2021 2/3 RS2A-PJ~RS2M-PJ Surface Mount Fast Recovery Rectifiers Package Outline SMA A A Dimensions in mm c a VM HE e A g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jun-2021 g e A D a 0.3 12 3/3
RS2M-PJ 价格&库存
很抱歉,暂时无法提供与“RS2M-PJ”相匹配的价格&库存,您可以联系我们找货
