FR107FL
FR107FL
    PJ(平晶)
    SMF(SOD-123FL)
    快/超快二极管 SOD123FL Vrrm=1000V Vf=1.3V Ir=5μA
FR107FL 数据手册
FR101FL~FR107FL Surface Mount Fast Recovery Rectifiers Features SOD-123FL  For surface mount applications  Glass passivated chip junction 1 2  Low profile package  Fast reverse recovery time  Lead free in comply with EU RoHS 2011/65/EU directive 1.Cathode 2.Anode Marking Code: FR101FL:F2 FR102FL:F2 FR103FL:F2 FR104FL:F2 FR105FL:F5 FR106FL:F7 FR107FL:F7 Absolute Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols FR101FL FR102FL FR103FL FR104FL FR105FL FR106FL FR107FL Units Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current at TC =125°C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Maximum Instantaneous Forward Voltage at 1 A IF(AV) 1.0 A IFSM 30 A VF 1.3 V IR 5 μA Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25 °C TA = 125 °C 100 Cj 15 pF Typical Thermal Resistance Note2 RθJA 85 °C/W Maximum Reverse Recovery Time Note3 Trr Junction Temperature TJ 150 °C TSTG -55 to +150 °C Typical Junction Capacitance Note1 Storage Temperature Range 150 250 500 nS Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 3. Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A www.pingjingsemi.com Revision:3.0 Nov-2021 1/3 FR101FL~FR107FL Surface Mount Fast Recovery Rectifiers 1.2 Instaneous Reverse Current (μA) Average Forward Current (A) Typical Characteristic Curves 1.0 0.8 0.6 0.4 0.2 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 100 T J =125°C 10 1.0 T J =25°C 0.1 175 00 T J =25°C Junction Capacitance (pF) Instaneous Forward Current (A) 40 60 80 100 100 10 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 120 140 T J =25°C 10 1 0.5 1.0 1.5 2.0 2.5 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 35 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles www.pingjingsemi.com Revision:3.0 Nov-2021 2/3 FR101FL~FR107FL Surface Mount Fast Recovery Rectifiers Package Outline SOD-123FL Dimensions in mm ∠ALL ROUND C A ∠ALL ROUND VM D E A pad e E Top View mil www.pingjingsemi.com Revision:3.0 Nov-2021 Bottom View A C D E e g HE max 1.1 0.20 2.9 1.9 1.1 0.9 3.8 min 0.9 0.12 2.6 1.7 0.8 0.7 3.5 max 43 7.9 114 75 43 35 150 min 35 4.7 102 67 31 28 138 UNIT mm g g A pad HE ∠ 7° 3/3
FR107FL 价格&库存
很抱歉,暂时无法提供与“FR107FL”相匹配的价格&库存,您可以联系我们找货
