1N4148WA
1N4148WA
    PJ(平晶)
    SOD-123W(CFP3)
    75V 150MA
1N4148WA 数据手册
1N4148WA Silicon Epitaxial Planar Switching Diode SOD-123W Features  For surface mounted applications  Fast reverse recovery time 2  Ideal for automated placement 1 1.Cathode 2.Anode Marking Code:T4 Absolute Maximum Ratings at TA = 25 ℃ Parameter Symbol 1N4148WA Unit Maximum Repetitive Peak Reverse Voltage VRRM 100 V Maximum RMS voltage VRMS 75 V Average Rectified Forward Current IF(AV) 150 mA Non-repetitive Peak Forward Surge Current at t = 1 s IFSM at t = 1 ms at t = 1 µs 0.5 1 A 4 Maximum Power Dissipation PD 400 mW Operating Temperature TJ 150 °C TSTG -55 to +150 °C Symbol 1N4148WA Unit V(BR)R 75 V Storage Temperature Range Characteristics at TA = 25 ℃ Parameter Reverse Breakdown Voltage at IR = 1 µA Maximum Forward Voltage at IF = 1 mA at IF = 10 mA 0.715 VF 0.855 at IF = 50 mA 1.00 at IF = 150 mA 1.25 V Peak Reverse Current at VR = 20 V,TJ = 25 °C at VR = 75 V,TJ = 25 °C 0.025 IR 1 at VR = 25 V,TJ = 150 °C 30 at VR = 75 V,TJ = 150 °C 50 Typical Junction Capacitance at VR = 0 V, f = 1 MHz Reverse Recovery Time at Irr = 0.1 X IR, IF = IR = 10 mA, RL = 100 Ω www.pingjingsemi.com Revision:2.0 Jul-2021 µA Cj 2 pF Trr 4 nS 1/3 1N4148WA Silicon Epitaxial Planar Switching Diode 500 Instaneous Reverse Current (μA) Total Power Dissipation (mW) Typical Characteristic Curves 400 300 200 100 0.0 25 75 50 100 125 150 100 T J =150°C 10 1 0.1 T J =25°C 0.01 175 00 Junction Capacitance (pF) Instaneous Forward Current (mA) 1000 100 10 1.0 T J =25°C 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 Instaneous Forward Voltage (V) www.pingjingsemi.com Revision:2.0 Jul-2021 20 40 60 80 100 120 percent of Rated Peak Reverse Voltage (%) Ambient Temperature (°C) 1.6 10 T J =25°C 1.0 0.1 0.1 1.0 10 100 Reverse Voltage (V) 2/3 1N4148WA Silicon Epitaxial Planar Switching Diode Package Outline SOD-123W Dimensions in mm A D b E A1 C ∠ALL ROUND L1 E1 A C D E E1 L1 b A1 max 1.3 0.22 1.8 2.8 3.9 0.45 0.7 0.2 min 0.9 0.09 1.5 2.5 3.6 0.25 0.5 max 51 8.7 71 110 154 18 28 min 35 3.5 59 98 142 10 20 UNIT mm mil www.pingjingsemi.com Revision:2.0 Jul-2021 8 ∠ 9° 3/3
1N4148WA 价格&库存
很抱歉,暂时无法提供与“1N4148WA”相匹配的价格&库存,您可以联系我们找货
1N4148WA
  • 50+0.08489
  • 500+0.06804
  • 3000+0.05778
  • 6000+0.05217
  • 24000+0.04731
  • 51000+0.04472
库存:5788
