2SC2873SQ-Y
2SC2873SQ-Y
    PJ(平晶)
    SOT89-3
    特性:低饱和电压。 高速开关时间。 推荐作为 PNP 晶体管 2SA1213SQ 的互补类型
2SC2873SQ-Y 数据手册
2SC2873SQ NPN Transistor Features SOT-89 ⚫ Low Saturation Voltage ⚫ High Speed Switching Time ⚫ As Complementary Type of the PNP Transistor 2SA1213SQ is Recommended. Equivalent Circuit 1.Base 2.Collector 3. Emitter Marking Code : 2SC2873SQ-O : MX 2SC2873SQ-Y : MY 2.Collector 1.Base 3.. Emitter Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Symbol Value Unit Collector Base Voltage VCBO 50 V Collector Emitter Voltage VCEO 50 V Emitter Base Voltage VEBO 5 V Collector Current IC 2 A Maximum Power Dissipation PD 0.5 W Junction Temperature TJ 150 ℃ TSTG -55 to +150 ℃ Symbol Value Unit RθJA 250 ℃/W Storage Temperature Range Thermal Characteristics Parameter Thermal Resistance Junction to Ambient www.pingjingsemi.com Revison:3.0 Feb-2022 1/7 2SC2873SQ NPN Transistor Electrical Characteristics (TA=25℃) Parameter Symbol Min. Typ. Max. Unit 70 -- 140 120 -- 240 20 -- -- ICBO -- -- 100 nA IEBO -- -- 100 nA V(BR)CBO 50 -- -- V V(BR)CEO 50 -- -- V V(BR)EBO 5 -- -- V VCE(sat) -- -- 0.5 V VBE(sat) -- -- 1.2 V FT -- 120 -- MHz Cob -- 30 -- pF DC Current Gain at VCE = 2 V, IC = 500 mA Current Gain Group O Y HFE at VCE = 2 V, IC = 2 A Collector Base Cutoff Current at VCB = 50 V Emitter Base Cutoff Current at VEB = 5 V Collector Base Breakdown Voltage at IC = 100 μA Collector Emitter Breakdown Voltage at IC = 1 mA Emitter Base Breakdown Voltage at IE = 100 μA Collector Emitter Saturation Voltage at IC = 1 A, IB = 50 mA Base Emitter Saturation Voltage at IC = 1 A, IB = 50 mA Transition Frequency at VCE = 2 V, IC = 500 mA Output Capacitance at VCB =10 V,IE = 0, f = 1MHz www.pingjingsemi.com Revison:3.0 Feb-2022 -- 2/7 2SC2873SQ NPN Transistor Typical Characteristic Curves 1000 1000 4mA 3.5mA hFE 500 Common Emitter VCE=2V 3mA DC Current Gain (mA) IC 600 Collector Current 800 700 Common Emitter Ta=25 ℃ 4.5mA 900 2.5mA 400 2mA 300 1.5mA 200 Ta=100 ℃ 300 Ta=25 ℃ 100 30 1mA 100 0 IB=500uA 0 2 4 6 8 10 Collector-Emitter Voltage 12 VCE 14 10 16 10 Collector-Emitter Saturation Voltage VCEsat (mV) Base-Emitter Saturation Voltage VBEsat (mV) Ta=25 ℃ Ta=100 ℃ β=20 100 10 2000 (mA) IC 300 100 Ta=100 ℃ Ta=25 ℃ 30 β=20 10 10 1000 100 Collector Current (mA) 1000 1000 IC (mA) 1000 VCE=2V f=1MHz IE=0/IC=0 300 Ta=25 ℃ Capacitance C (pF) Cib 100 IC (mA) IC 1000 Collector Current Collector Current 1000 100 Collector Current 1000 300 1 (V) Ta=100 ℃ 30 Ta=25 ℃ 10 100 Cob 10 3 1 0.0 0.2 0.4 Base-Emitter Voltage www.pingjingsemi.com Revison:3.0 Feb-2022 0.6 VBE 0.8 (V) 1.0 1 0.1 1 Reverse Voltage 10 VR 20 (V) 3/7 2SC2873SQ NPN Transistor Package Outline SOT-89 Dimensions in mm Ordering Information Device Package 2SC2873SQ SOT-89 www.pingjingsemi.com Revison:3.0 Feb-2022 Shipping 1,000PCS/Reel&7inches 3,000PCS/Reel&13inches 4/7 2SC2873SQ NPN Transistor Conditions of Soldering and Storage  Recommended condition of reflow soldering Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revison:3.0 Feb-2022 5/7 2SC2873SQ NPN Transistor Package Specifications  The method of packaging (1,000PCS/Reel&7inches) Cover Tape 1,000 pcs per reel SOT-89 Carrier Tape 8,000 pcs per box 8 reels per box 32,000 pcs per carton 4 boxes per carton  Embossed tape and reel data D A T1 E B G F Reel (7'') www.pingjingsemi.com Revison:3.0 Feb-2022 symbol Value(unit:mm) A Φ179±1 B 60.5±0.2 C 15.3±0.3 D 12.5~13.7 E Φ13.5±0.2 F Φ10.0±0.2 G 2.7±0.2 T1 1.0±0.2 C 6/7 2SC2873SQ NPN Transistor Package Specifications  The method of packaging (3,000PCS/Reel&13inches) 3,000 pcs per reel SOT-89 9,000 pcs per box 3 reels per box 36,000 pcs per carton 4 boxes per carton  Embossed tape and reel data B A T E D F Reel (13'') www.pingjingsemi.com Revison:3.0 Feb-2022 symbol Value(unit:mm) A Φ330±1 B 12.7±0.5 C 16.5±0.3 D Φ99.5±0.5 E Φ13.6±0.3 F 2.8±0.3 T1 1.9±0.2 C 7/7
2SC2873SQ-Y 价格&库存
很抱歉,暂时无法提供与“2SC2873SQ-Y”相匹配的价格&库存,您可以联系我们找货
2SC2873SQ-Y
  • 10+0.42066
  • 100+0.33254
  • 300+0.28847
  • 1000+0.25542
  • 5000+0.22896
  • 10000+0.21579
库存:2440
