FMMT493
NPN Transistor
SOT-23
Features
For Switching and AF Amplifier Applications.
Equivalent Circuit
1.Base 2.Emitter 3.Collector
3.Collector
Marking Code : 493
1.Base
2.. Emitter
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
120
V
Collector Emitter Voltage
VCEO
100
V
Emitter Base Voltage
VEBO
5
V
Collector Current
IC
1
A
Maximum Power Dissipation
PD
250
mW
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revision:2.0 Sep-2021
1/6
FMMT493
NPN Transistor
Electrical Characteristics (TA=25℃)
Parameter
Symbol
Min.
Max.
Unit
100
100
300
at VCE = 10 V, IC = 500 mA
60
at VCE = 10 V, IC = 1 A
ICBO
100
nA
IEBO
100
nA
V(BR)CBO
120
V
V(BR)CEO
100
V
V(BR)EBO
5
V
VCE(sat)
300
mV
600
VBE(sat)
1.15
V
VBE(on)
1
V
FT
150
MHz
Cob
10
pF
DC Current Gain Note1
at VCE = 10 V, IC = 1 mA
at VCE = 10 V, IC = 250 mA
Collector Base Cutoff Current
at VCB = 100V
Emitter Base Cutoff Current
at VEB = 4 V
Collector Base Breakdown Voltage
at IC = 100 μA
Collector Emitter Breakdown Voltage
at IC = 1 mA
Emitter Base Breakdown Voltage
at IE = 100 μA
HFE
Collector Emitter Saturation Voltage
at IC = 500 mA, IB = 50 mA
at IC = 1 A, IB = 100 mA
Base Emitter Saturation Voltage
Base Emitter On Voltage
Transition Frequency
at VCE = 10 V, IC = 50 mA,f = 100 MHz
Output Capacitance
at VCB = 10 V, f = 1 MHz
2/6
FMMT493
NPN Transistor
Typical Characteristic Curves
8
400
VCE= 10V
o
Ta=100 C
hFE
27uA
24uA
DC Current Gain
Collector Current
350
30uA
6
IC
(mA)
Common
Emitter
Ta=25℃
21uA
4
18uA
15uA
12uA
2
300
250
200
o
Ta=25 C
9uA
150
6uA
IB=3uA
4
6
8
10
Collector-Emitter Voltage
12
14
1
100
Collector Current
1000
IC
1000
(mA)
1000
β=10
β=10
Collector-Emitter Saturation Voltage
VCEsat (mV)
Base-Emitter Saturation Voltage
VBEsat (mV)
10
VCE (V)
800
Ta=25℃
600
400
Ta=100℃
200
0.1
1
10
Collector Current
100
IC
100
Ta=100℃
Ta=25℃
10
0.1
1000
1
10
100
Collector Current
(mA)
180
IC
1000
(mA)
1000
(mA)
140
100
Ta=100℃
IC
120
100
Collector Current
fT (MHz)
160
80
60
40
Ta=25℃
10
1
VCE=10V
VCE=10V
o
Ta=25 C
60
Collector Current
IC
80
100
(mA)
0.1
100
200
300
400
500
600
Base-Emitter Voltage
700
800
900
1000
VBE (mV)
300
Power Dissipation
PD (mW)
250
200
150
100
50
50
75
Ambient Temperature
100
125
150
Ta (℃)
3/6
FMMT493
NPN Transistor
Package Outline
SOT-23
Dimensions in mm
Ordering Information
Device
Package
Shipping
FMMT493
SOT-23
3,000PCS/Reel&7inches
4/6
FMMT493
NPN Transistor
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/6
FMMT493
NPN Transistor
Package Specifications
The method of packaging
Cover Tape
3,000 pcs per reel
SOT-23
Carrier Tape
30,000 pcs per box
10 reels per box
120,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T2
T1
Symbol
A
B
C
E
F
D
T1
T2
B
C
E
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
F
Reel (7'')
6/6
很抱歉,暂时无法提供与“FMMT493”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29949
- 100+0.23685
- 300+0.20564
- 3000+0.17529
- 6000+0.15650
- 9000+0.14721
