TIP125/126/127
Silicon PNP Darlington Power Transistors
DESCRIPTION
・With TO-220 package
・DARLNGTON
・High DC durrent gain
・Low collector saturation voltage
・Complement to type TIP120/121/122
APPLICATIONS
・Designed for general–purpose amplifier
and low–speed switching applications
PINNING
PIN
DESCRIPTION
1
Base
2
Collector;connected to
mounting base
3
Emitter
Absolute maximum ratings(Tc=25℃)
SYMBOL
PARAMETER
CONDITIONS
TIP125
VCBO
VCEO
Collector-base voltage
Collector-emitter voltage
TIP126
Open emitter
Emitter-base voltage
IC
-80
TIP127
-100
TIP125
-60
TIP126
UNIT
-60
Open base
TIP127
VEBO
VALUE
-80
V
V
-100
Open collector
-5
V
Collector current-DC
-5
A
ICM
Collector current-Pulse
-8
A
IB
Base current-DC
-120
mA
PC
Collector power dissipation
TC=25℃
65
Ta=25℃
2
W
Tj
Junction temperature
150
Tstg
Storage temperature
-65~150
www.slkormicro.com
1
TIP125/126/127
CHARACTERISTICS
Tj=25℃ unless otherwise specified
SYMBOL
PARAMETER
CONDITIONS
TIP125
VCEO(SUS)
Collector-emitter
sustaining voltage
TIP126
MIN
TYP.
MAX
UNIT
-60
IC=-0.1A, IB=0
TIP127
V
-80
-100
VCEsat-1
Collector-emitter saturation voltage
IC=-3A ,IB=-12mA
-2.0
V
VCEsat-2
IC=-5A ,IB=-20mA
-4.0
V
Base-emitter on voltage
IC=-3.0A ; VCE=-3V
-2.5
V
-0.2
mA
-0.5
mA
-2
mA
300
pF
VBE
ICBO
ICEO
Collector
cut-off current
Collector
cut-off current
TIP125
VCB=-60V, IE=0
TIP126
VCB=-80V, IE=0
TIP127
VCB=-100V, IE=0
TIP125
VCE=-30V, IB=0
TIP126
VCE=-40V, IB=0
TIP127
VCE=-50V, IB=0
IEBO
Emitter cut-off current
VEB=-5V; IC=0
hFE-1
DC current gain
IC=-0.5A ; VCE=-3V
1000
hFE-2
DC current gain
IC=-3.0A ; VCE=-3V
1000
Cob
Output capacitance
IE=0 ; VCB=-10V,f=0.1MHz
www.slkormicro.com
2
TIP125/126/127
www.slkormicro.com
3
TIP125/126/127
TO-220 Package Dimensions
Unit: mm
Symbol
W
W1
W2
W3
W4
Size
Min
Max
9.66
10.28
2.54(TYP)
0.70
0.95
1.17
1.37
1.32
1.72
www.slkormicro.com
Symbol
W5
L
L1
L2
L3
Size
Min
9.80
9.00
6.40
2.70
12.70
Max
10.20
9.40
6.80
2.90
14.27
4
Symbol
L4**
L5
T
T1
T2
Size
Min
6.20
2.79
4.30
1.15
2.20
Max
6.60
3.30
4.70
1.40
2.60
Symbol
T3
G(Φ)
Size
Min
0.45
3.50
Max
0.60
3.70
很抱歉,暂时无法提供与“TIP127”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.84356
- 50+1.38824
- 150+1.23660
- 500+1.04750
- 2500+0.96326
- 5000+0.91260
- 国内价格
- 1+0.86999
- 30+0.83999
- 100+0.80999
- 500+0.74999
- 1000+0.72000
- 2000+0.70200
