PTN162H250S4B250
PTN162H250S4B250
    PROSEMI(普罗森美)
    DFN2
    双向ESD 4.5V截止 峰值脉冲电流:180A@8/20US
PTN162H250S4B250 数据手册
High Capacitance Series ESD Protection PTN162H250S4B250 Features Ultra small package: 1.6x1.0x0.5mm Protects one date or power line Working voltage: 4.5V 2-pin leadless package RoHS Compliant Ro H S 2002/ 95/ EC IEC COMPATIBILITY (EN61000-4) DFN1610 IEC 61000-4-2 ±30kV contact ±30kV air IEC 61000-4-5 (Lightning) 135A (8/20μs) Mechanical Characteristics Applications Mobile Phones Package: DFN1610-2 (1.6x1.0x0.5mm) Battery Protection Case Material: “Green” Molding Compound. Power Line Protection UL Flammability Classification Rating 94V-0 Vbat pin for Mobile Devices Moisture Sensitivity: Level 3 per J-STD-020 Hand Held Portable Applications Terminal Connections: See Diagram Below Schematic & PIN Configuration DFN1610 Specifications are subject to change without notice. C PROSEMI Document No:P17010012S 1 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN162H250S4B250 Absolute Maximum Rating (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power (tp=8/20μs waveform) Ppp 2500 W Peak Pulse Current (8/20µs) Ipp 180 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics(TA=25ºC) Parameter Test Condition Symbol Min Typ VRWM Reverse Working Voltage VBR Max Unit 4.5 V Breakdown Voltage IT = 1mA 4.8 V Reverse Leakage Current VRWM = 4.5V IR 0.2 uA Clamping Voltage IPP = 20A (8 x 20µs pulse) VC 7 V Clamping Voltage IPP = 180A (8 x 20µs pulse) VC 13.8 V Junction Capacitance VR = 0V, f = 1MHz CJ 250 pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I Parameter IF Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT VC VBR VRWM IR VF IT V Test Current IPP Note:. 8/20μs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:P17010012S 2 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN162H250S4B250 Typical Performance Characteristics(TA=25°C unless otherwise Specified) Specifications are subject to change without notice. C PROSEMI Document No:P17010012S 3 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN162H250S4B250 Package Mechanical Data DIMENSIONS SYM MILLIMETERS NOM MAX 0.50 0.55 INCHES MIN NOM MAX 0.018 0.020 0.022 A MIN 0.45 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.75 0.80 0.85 0.030 0.032 0.034 c 0.10 0.15 0.20 0.004 0.006 0.007 D 1.55 1.60 1.65 0.062 0.064 0.066 e 1.10 BSC 0.044 BSC E 0.95 1.00 1.05 0.038 0.040 0.042 L 0.35 0.40 0.45 0.014 0.016 0.018 h 0.15 0.20 0.25 0.006 0.008 0.010 Suggested Land Pattern SYM DIMENSIONS MILLIMETERS INCHES X 1.00 0.040 Y1 0.62 0.025 Y2 0.60 0.024 Y3 1.22 0.049 Z 1.85 0.074 Ordering information Order code PTN162H250S4B250 Package DFN1610 Base qty 3k Delivery mode Tape and reel Specifications are subject to change without notice. C PROSEMI Document No:P17010012S 4 of 4 www.prosemitech. com
PTN162H250S4B250 价格&库存
很抱歉,暂时无法提供与“PTN162H250S4B250”相匹配的价格&库存,您可以联系我们找货
