S5A THRU S5M
Surface Mount General-purpose Rectifiers
Reverse Voltage 50 ~ 1000 V
Forward Current 5.0 A
www.prosemitech.com
Features
Low reverse leakage
High forward surge capability
High reliability
High temperature soldering guaranteed:
260℃/10seconds
Lead and body according with RoHS standard
Ro H S
2002/95/EC
Green compound with suffix "-F" on Marking
DO-214AB/SMC
Mechanical Data
Case:DO-214AB Molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead: Pure tin plated, lead free
Maximum Ratings & Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbols
S5A
S5B
S5D
S5G
S5J
S5K
S5M
Unit
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Maximum average forward rectified current
IF(AV)
5.0
A
IFSM
150
A
VF
1.1
V
Non-repetitive peak forward surge current
8.3 ms singlehalf sine-wave
@IF=5.0A
Maximum forward voltage
@VDC
TA= 25℃
Maximum reverse current
TA= 125℃
Typical thermal resistance (Note 1)
VR=4.0V,f=1MHz
Type junction capacitance
Operating junction and storage temperature
rang
5
IR
100
μA
RθJA
47
℃/W
CJ
65
pF
TJ, TSTG
-55 --- +150
Note:
1) Thermal resistance from junction to ambient , PCB mounted.
Specifications are subject to change without notice.
C PROSEMI Document No:HEX35022147Z
1 of 3
www.prosemitech.com
S5A THRU S5M
www.prosemitech.com
Characteristic Curves
FORWARD CURRENT DERATING CURVE
10
IF(A) Average Forward Rectified Current (A)
IF Instantaneous Forward Current (A)
TYPICAL FORWARD CHARACTERISTIC
1
Tj=25℃
0.1
0.2
0.6
1
1.4
6
5
4
3
2
1
25
50
75
100
150
125
175
Tamb, ambient temperature (°C)
VF Instantaneous Forward Voltage (V)
MAXIMUM NON REPETITIVE PEAK FORWARD
Typical Reverse Characteristics
SURGE CURRENT
10
120
Reverse Current(uA)
IFSM Peak Forward Surge Current (A)
150
90
60
1
0.1
30
Tj=25℃
Tj=25℃
0.01
10
100
Number of Cycles at 60 Hz.
0%
20%
40%
60%
80%
100%
Percent Of Rated Peak Reverse voltage %
2 of 3
www.prosemitech.com
S5A THRU S5M
www.prosemitech.com
Package Outline
0.240(6.10)
0.217(5.50)
0.128(3.25)
0.108(2.75)
0.280(7.10)
0.256(6.50)
0.012(0.305)
0.006(0.152)
0.106(2.70)
0.083(2.10)
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX
0.331(8.40)
0.291(7.40)
Unit: inch (mm)
Package Information
Qty:3,000 /Tape and reel
3 of 3
www.prosemitech.com
很抱歉,暂时无法提供与“S5M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.64875
- 100+0.51196
- 600+0.39225
- 1200+0.38833
- 3000+0.33412
